Blainestang
Yep. 230 miles is fine for many, many use cases. The Lightning's biggest "issue" right now is probably the charge rate.I would have 0% range anxiety with 230 miles of range. I'll be very happy if real world range exceeds that figure but would much rather have them focus on charging speed.
44 minutes to add ~150 miles in the SR (15-80%) is actually an average of ~100kW, so that's pretty good, BUT the inherently bad efficiency of a truck really hurts the miles/minute rate.
41 minutes to add ~195 miles in the ER is substantially better. That's averaging ~150kW all the way up to 80%! So, it's either 150kW all the way to 80%, or it's even faster early in the charge curve. Hopefully the latter, IMO, so one could add, say, 150 miles in 25 mins or so.
Personally, my biggest concern is if I want to tow longer distances. The huge efficiency hit is a double-whammy. One, now you only get 1 mi/kWh, probably. And two, in order to make it to the next charging station, you may have to charge nearly all the way full (especially with SR), which for the Mach E means VERY slow charge rates above 80%.
We'll see! Still lots and lots to learn about these trucks!
