Tambow
Update on the braking issue.
I took the trailer to the airstream dealer and they towed the trailer with their truck and the brakes worked fine. I tried my f150 Powerboost again and the brakes worked fine for an hour or so.
After a couple of hours I began to have the "No Tailer" issue again and the brakes did not work when I pressed the brake pedal or the brake lever.
I plugged and unplugged the 7 pin several times and still no brakes. I turned the truck off and tried the plug again but it still did not work.
Then I remembered someone on the thread tried powering down the trailer. So I put the trailer in storage mode and then powered it back up and tried again and the brakes worked.
I keep wondering if there is something wrong with the brakes on the Airstream instead of with the truck. Or if there is a brake controller in the trailer that needs servicing. I'll call the airstream dealer on Tuesday and see if they have any ideas with the new information.
