‼️ UPDATE FORD E-RAPTOR grille swap and install tutorial
DesertEV
Matthew
El Paso, TX
Ford F-150 Lightning
The grille I ordered from EBay will come with the letters in a separate box. There are alignment holes molded into the back of the grille to properly mount the letters after delivery🤙🏼
Thank you. Are there holes for the cameras? I have a XLT. Would it void a warranty?
N87
Leo
communic2
23 FL
I have one on order. There are no holes for the cameras, to the best of my knowledge.
AZT9
AZT9
Peoria, AZ
No camera mount. I used a OEM mount for a 2019 Raptor. Can not void your warranty!!!
DesertEV
Matthew
El Paso, TX
I'm looking into this grill and am thinking about designing a custom mount for the camera that I could just 3d print. We'll see how good my CAD skills are. If I can't make a good enough design, I'll probably just use the parts you did but non-sprayer version.
Are you doing this? If so, I’m in. Will I have any camera or sprayer issue with a 23 XLT Lightning?
dcshoes23
I received my grille and have begun designing the camera mount. One issue I'm running into is that our camera's connector comes out to the side.
@AZT9 is your camera connector behind the grille or did you have to cut into the grille in order for the the connector and cable to fit? If you have any pictures of how the connector/cable go once mounted, that would be helpful. :) Thanks!
Bcon91
23 Ford Lightning XLT
@AZT9 @Zaptor I have an XLT without the sprayer. Based on your installs, will I still need a different camera housing/mount, or will the one in my current emblem work?
Zaptor
.......... Trophy husband
You could do it with the existing mount, but it will require modifications with a Dremel and glue either way in my experience and judgement. The Raptor camera mount was like seventeen bucks so worth it IMO
-Zap
Minh
Minh
NJ
If I’m do this again (still considering) I would just drill a circular hole into the grille and use JD weld as a mount. Since it take a little time to harden you can work it to get the angle you need to align the camera for 360 before you let it set. This obviously won’t work for sprayer but I think to drill a circle is much easier to cut and insert the camera mount and also smaller to conceal the imperfection.
dippinMike
Torrance, CA
2022 F150 Lightning Lariat
looks good bro! did you post a link to the grille already? i looked but didn't see a link unless i missed it
Blochead21
PA
Black 22 XLT 311pkg
I like the grille, not with the extra lightning lettering, do you have a link the grille he used?
It’s the same grill from the Original Post. They just modified it for the letters and the lighting.
Bcon91
-Zap
Did you notice any change in range with the new grill?
