+1000W to 2.4Kw ProPower - PowerBoost
necser
Sergey
Calgary, Canada
2021 F-150 PowerBoost Lariat
Hi guys, unfortunately after I took delivery my PB with 2.4kW ProPower, discovered that its not enough to run my 13500BTU camper AC.
So I see the generators/inverters can be wired in parallel for combined wattage.
Anybody tried adding 1000W (or bigger) inverter to the battery and parallel it with the internal Generator to get 3500W+ noiseless 120V? or maybe instead of the inverter, parallel with the small (quieter) generator for combined wattage?
toyko joe
earth
2021 F150 XLT PowerBoost FX4
I have not, I am curious if you can just buy the 7.2kw "generator" to upgrade your current. I have tried to identify the part numbers or wiring diagram for all these 2.4kW and 7.2kW "generators" but I haven't had great luck yet.
mnstang
Nick
MN
2021 F-150 Lariat PB Leadfoot
US Gov
I was worried about this too, so when I had a chance to reorder mine (first one was just the 2.4kw propower) I made sure it had the 7.2kw this time around, glad I did it! I read somewhere that it would not be as easy as switching out the head unit to change it to 7.2kw. I think the wiring and module is completely different as well. Might be worth it to trade it in on another brand new truck!
wayfarer556
Austin, TX
2021 F150 XLT Powerboost 302A
I have the 2.4 on mine...when it comes for me to get an RV, I'm going to get one of these too and see if that helps:
https://www.softstartrv.com/
Might be cheaper and less of a pain than trading in for a whole new truck, especially today.
necser
necser
Sergey
Calgary, Canada
Nice find! Want to setup group buy? Anybody else interested?
necser
necser
Sergey
Calgary, Canada
ordered one, received the next day with DHL to Canada, installed and it works perfectly with my 2.4kw PowerBoost!!!
this should be part of every RV AC!
Way2qk4u2c
Michael
Austin
2021 F-150 2015 Mustang GT
Network admin
I actually bought one of these for my home A/C. My amp draw was as high as 50amps but with it installed I don’t go above 11 amps. I can now use my 7.2kw system to power my house including AC if needed. Definitely a sweet device for home and RV’s!
wayfarer556
Austin, TX
Honestly you're the first person I've read who's confirmed that this thing will work for those of us with the 2.4 kw system. Awesome, thank you for posting!
necser
necser
Sergey
Calgary, Canada
totally works, works well, no issues with Dometic Brisk II 13000 BTU AC. But from what I read, works with all other units too.
Mine peaks at 1500W. ?
AutonomousHybridF150
Kristopher
Pensacola Fl
2021 F150 Powerboost
Adjuster
That’s amazing news. Now we just need to figure out how to add something like this to the 2.4 and 7.2 kw truck systems :)
But without reading the instructions, it appears that it’s just a “hard start” capacitor like what you use when your condenser is going bad and not starting up.
can anyone confirm that is what this is?
minirx7
Ed
Toronto
21 F150 Lariat Sport 502A Screw Max Tow 3.5L
This is fantastic info. I have a 2kw Ecoboost Gas F150, and i have my micro-air easy start but have not yet installed it yet (hopefully this weekend). I am really hoping i can get my AC working off of the F150 which will make those pit stops a lot easier to deal with !!
minirx7
Ed
Toronto
I have the exact same AC as you on my brand new 21 Jayco 267BHS.. Cant wait to install it!!
minirx7
Ed
Toronto
No it is not a hard start capacitor. IN fact it is actually logic driven. On the Micro-air you need to train it to learn how the compressor starts.
minirx7
Ed
Toronto
So bad news i installed the micro-air 2 weeks ago before my long trip. Plugged it into the F150. Oddly, it AC starts to run, then when the comrpessor tries to kick in, AC turns off then back on (fan only). Every time the compressor kicks in it turns off and on again.
F150 never shows overload at all... Very disappointed. as i ahd my hopes up.
