Powerboost 2.4KW upgrade to 7.2KW
Kefoster2
Kenneth
Galloway Ohio
F150
It is my understanding that it is a hardware change on the inverter.. I think with the 2.4kw you still have an inverter under the back seat.. With the 7.2kw it's all under the truck..
The inverter under the back seat is just like my 2017 2.7 ECO in which the inverter provided AC voltage to the two plugs in the cab.
daemonic3
Terry
Sacramento, CA
2017 F150 3.5EB
Yes.
Just like a normal fuel generator (propane/gas/diesel) you have to run the engine to make electricity for use.
Not true, the PB is *supposed* to use the battery until the load hits above a threshold OR the the 1.5kWh battery needs to recharge. I saw in a video that the truck gives you a warning that the engine will periodically turn on as needed (so you don't leave it in an enclosed garage or something else dangerous).
With the 2kW propower (any gas engine) the truck has to run all night.
daemonic3
Terry
Sacramento, CA
2017 F150 3.5EB
Some clarifications on what is under the seats:
The Powerboost propower (2.4 or 7.2kW) will *still* have some kind of inverter under the 40% rear seat.
The non-Powerboost propower (2kW) will have an inverter under the 40% seat AND some extra components under the 60% seat. Until someone pops the plastic off the box, we don't know if that is the two 12V batteries, or just the larger invertor (though why is there still one on the 40% side?)
So NO MATTER WHAT TRUCK there is something under that 40% seat. I don't know why the PB needs it as the internal outlets are rated 20A not 400W so it is not like it needs a small inverter, unless it is STRICTLY to support that "lower power mode" on the PB Propower.
daemonic3
Terry
Sacramento, CA
2017 F150 3.5EB
In this video at around 7m, he starts showing the app and how it displays Propower. There is a "low power mode" that it default starts in, and supports up to 400W. So that is my theory as to why the PB still has an inverter under the 40% seat, that it is much more efficient at light loads, while the one under the chassis is only efficient at higher loads.
Jaym69
Jason
WV
2012 F150
Investigator
Our PB F-150 will be equipped with the standard 2.4kW setup. If we are remotely camp'n with our trailer plugged in, do we have to run the truck engine through the nite to maintain electricity to the trailer?
I believe it will only run the engine to charge the battery when needed if you leave it in generator mode all night. Better than running a portable generator all night that runs gas constantly.
I have not tested mine yet, but that is what I understand to be true.
currybob
Bob
Alexandria Alabama
2021KRF150 PB; 2020 LexusRX350; 2021 Mazda Miata
Retired Physicist from federal government; Army Veteran
Yes.
That is not correct. Only the PowerBoost will run as needed to keep the battery charged, that is for the 2.4kw and the 7.2kw. Where are you people getting some of this information from?
discothan
SW Michigan
2021 F150 XLT
I've got the 2.0kwh on the 3.5L EB. I think that is the difference, I have to run my engine for the generator to work correctly. I will re-test once it warms up some more and snow/ice melts.
satexas
satexas
Russ
San Antonio
F150 PB 2021 L502a
Of course, because unlike the Powerboost, you don’t have a huge battery pack on your undercarriage.
Powerboost is a hybrid.
Wilsons66605
Scott
Topeka KS
2021 Power Boost Platinum, 2019 Raptor
My sales guy told me that the 7kw is something they do at dealership.
for what that is worth
dantheman
BCS TX
21 XLT powerboost
This is not true. It is a non-trivial upgrade from 2.4 to 7.2. In another thread, it was said the cables are larger and the inverter is different on top of the external differences.
Wilsons66605
Scott
Topeka KS
I took it at face value
Mjulian06
Jay
Ford F-150 Powerboost
The upgrade from the "build your own" tool on the website is only $750. What I want to know is: how much does it cost to upgrade from a 2.4kw to a 7.2kw after you purchase the vehicle? I keep looking for an answer and no one seems to have an answer. From what I've read here, it really isn't a substantial job. Replacing the wires, inverter, hardware in the truck bed, and software isn't that big of a deal. It should only take a service guy that is familiar with the vehicle a couple of hours.
Has anyone done it on theirs?
currybob
Bob
Alexandria Alabama
Your idea of a big deal is far different from mine. Lol
There are many expensive parts that would have to be removed and new expensive parts added plus labor at whatever their rate is ($60-$80 per hr). If you don't have it done by Ford you void your warranty. The removed parts would just be yours then.
I would bet, it seriously would be in the 2k-3k range to be honest.
I had read several stories of people adding tow mirrors to trucks that did come with them. Most were stating prices just short of $1800, the option is $250.
Did you order the PowerBoost without the 7.2kw or something?
