Unless I am misunderstanding your question, that is just stability control which ford calls "Co-pilot 360" and is standard on all trims.I can't find if the new F-150 lightning has anti fishtail safety feature. Or maybe I just missed it?
I think you didn't misunderstood me. Stability control is logically the anti fishtail I was looking for. This is the feature that makes you go straight and prevent getting vehicle from spinning out if control usually cause by oversteering on a slick road. Thanks!Unless I am misunderstanding your question, that is just stability control which ford calls "Co-pilot 360" and is standard on all trims.
I was thinking pretty much like you. Curious how ford will translate this technology to an electric motor driven axle. I could be wrong but I thought the process for this safety feature is to "tame" the vehicle by automatically slowing down the rear wheels independent from each other to correct the fishtailing. Since lightning has 1 electric motor driving both rear wheels, I assume they always turn in constant synchronization. Hope it is still effective as it can be slick here in Vancouver Canada.Ford has a decent stability control / traction system; but would be interesting how the Lightning handles it since it's an independent suspension with a single motor per axle.
It can still apply the brakes to separate wheels.I was thinking pretty much like you. Curious how ford will translate this technology to an electric motor driven axle. I could be wrong but I thought the process for this safety feature is to "tame" the vehicle by automatically slowing down the rear wheels independent from each other to correct the fishtailing. Since lightning has 1 electric motor driving both rear wheels, I assume they always turn in constant synchronization. Hope it is still effective as it can be slick here in Vancouver Canada.
Also keep in mind the F150 EV is more weight balanced than a regular pickup as the battery evenly distributes the weight front and rear.Stability control is logically the anti fishtail I was looking for.
Yes, that is very good to know also it has a lower center of gravity due to the batteries.Also keep in mind the F150 EV is more weight balanced than a regular pickup as the battery evenly distributes the weight front and rear.
I am hoping A/T tires they offer on the lighting will be severe snow rated.Yes, that is very good to know also it has a lower center of gravity due to the batteries.
Makes for better handling like a sedan with less body roll.
OP if you want better traction in Canadian weather, consider changing out your tires to snow rated (snowflake) or off road type.
Four motors, three motors, two motors, or a single engine; it doesn't matter to the road how the vehicle dynamics computer varies the speeds of the individual wheels....Since lightning has 1 electric motor driving both rear wheels, I assume they always turn in constant synchronization...
This will definitely be something to keep an eye on, to maximize range Lightning will have OEM low rolling resistance tires. Many dedicated winter tires also tend to have low rolling resistance. With the preposterous torque from the electric motors, it will be interesting to see how it handles low traction situations.I am hoping A/T tires they offer on the lighting will be severe snow rated.
