2023 XLT SR Won't charge
I am writing with an update.
Truck was diagnosed today by Ford. Failed Part No. LK9Z10B689M
Online, it looks like this is described as "Drive Motor Battery Pack Charger" or "Battery Charger."
Taxman, this is what you thought when you say "onboard charger" right?
Service tech said the part costs about $2k. I see online sales of the part in the $1,300 - $1,500 range. But, the service tech confirmed that the part and service is covered under the 8 year/100k battery-ev component warranty with no deductible.
The other good news is that the part is expected to arrive tomorrow. So, that seems like a significant improvement in the parts supply chain compared to other threads I read on this forum from maybe a year ago.
Yes, this is your AC to DC converter that converts 48 amp 240v power to ~390~400v DC current.
scruvs
2023 F-150 Lightning XLT Standard Range
My truck was completed at the end of the day. I’ll pick it up tomorrow.
I asked what this repair would have cost if it was not covered by the 100k EV component warranty and they said $3k. $2k for the part and $1k for the labor.
I like to share these costs so folks can consider whether an extended warranty makes sense or not. But, if I remember correctly, I think Ford’s extended warranty expressly excludes extending coverage of the EV Components beyond 100k miles.
I think the costs are also helpful in getting an idea of how much labor is involved.
Hopefully, by the time most of us hit 100k miles, someone has posted a YouTube video on how to swap out this part. I suspect it’s (1) getting to it; (2) disconnecting some electrical connectors; (3) clamping some cooling lines; and (4) putting it all back together. if so, I bet step 1 is the hard part.
BabyDoc1012
NC
2023 XLT, 2022 Mustang Mach 1, 2021 Expedition
Glad it got fixed so quick! I bet step number 1 on your list is having to drop the entire battery. Which would explain the labor costs. It will be interesting to see what kind of 3rd party repair shops open up as EVs become more mainstream and how the prices will compare to dealership.
Remember to share which parts were replaced once you get back from the pick-up.
scruvs
Everything seems to be working well now. Only one large Frunk clip lost in this service. I had the advisor text me an IOU for one large clip and explained that it might still require the entire panel to be ordered.
Service Notes:
Installed LK9Z 10B689 M
Scanned codes and found SOBDM code P0D80:00.
Followed PPT I1 Y, I2 monitored pids and during initial plugin, FREQ pid greater than 0, and S2 switch displayed closed.
Fault happens again and code is set, Y I7, no corrosion performed self test again and code returns.
Removed and replaced SOBDM, reassembled and programmed. Rested and concern is no longer present.
Labor op: 12651D63: 3.0, 12651DE .2, 12651DX1 .1, 12651D45E .3
3.6 Total
jjupi91897
Joseph
Ford F-150 Lightning
Thank God you're getting the part so quickly. All that may change in the future due to these crazy tarrifs.
El Duderino
2025 Flash
For future reference, electric motors in EVs are often referred to as e-machines or e-drive. The reason they don't say electric motor is because an e-machine can motor and generate. So it'll spin your wheels or it will regenerative brake to put energy back into the battery. Tier 1 suppliers that provide these motors refer to them as e-machines.
