2024 FLASH with Tow Technology (Brake Controller)
Wildneg
Kevin
2024 FORD LIGHTNING FLASH
Solution Architect
So I've been researching and it's a mix bad of information.
I'm looking for exact part I need to get built in in functionality on the truck and the gain control, where the coin slot is.
I saw part ML3Z19H332AA mentioned. But the. I see ML3Z19H332AB. Is it correct AB is the one? I read both work but AB is just the newer version and replaces AA.
This comes with the controller module and the gain slide/control, correct? Sound like my truck has a controller but YOU HAVE TO REPLACE the one there with this module and then hook up the gain control. Alot of reading, this is what I e concluded.
So if all that is correct, I'll need to then do some updates with ForScan. I have not tracked those specific changes yet, but sound like once that is updated, everything becomes available, correct?
Just wanted to verify so I order the right thing and have it all ready. Have to take the riding mower in and tractor for yearly maintenance.
Thanks in advanced!
