Azgunguy
- First Name
- Michael
- Jan 7, 2024
- Northern Arizona
- 2023 Lightning Pro and 2012 Expedition Fleet
I have a '23 Pro ER with Max Tow (no tow tech). It came from the factory with the trailer brake control module installed under the dash. I purchased the proper dash controller switch that fits where the coin slot goes and installed it. I have gone into forscan and turned on every single trailer brake module that i could find. However i only did it where you can change it from "disabled" to "enabled". I do not know the values to change for the "AS BUILT Format". Im still going through livinitup's spreadsheet to figure it out, but if anyone has any insight that would be greatly appreciated.
