3D Printed Rear Camera Mount
Atomic92
South Carolina
2021 F-150 platinum
No tape or anything, just kept in place by pressure. Slides into the space above the headliner and twists. I've only ever tested it on my truck so I have no idea if the tolerances there vary or anything.
Perfect, Thank you again. I can always add the tape if it needs it.
What camera are you running? My Thinkware Rear camera doesn't like being mounted flat against the glass and I loose about 1/8th the picture because it can record it's own mount.
nearly
nearly
2021 F150 Lariat
Thinkware u1000. There's to stl's in there, one has a vertical face and a horizontal face. If your camera can see its own mount you probably want to use the horizontal one and have the mount be above the lens then rotate the lens 90 degrees.
