Anyone added aftermarket subwoofer to standard B&O system?
opey1513
Charles
Trenton Mi
21 F150
This part of forscan allows you to change the output from the b&o dsp. You can make the sub output a signal out instea of a speaker out. The difference is the voltage remains constant and doesnt roll off when distortion is detected.
can you please explain how to do it and what you used. I tried doing it and it keeps telling me incorrect sum used or something like that
Blaze
Ben
Georgia
2021 F150 Lariat
I had one in my first 21, all I did was unplug the factory sub and tapped that plug to the amp, it worked fine just with that halfass setup.
krzy4ut
bk
22 F150
How did you get the signal to the Amp? I'm hearing so many different opinions on if and how to add a subwoofer to a BO Unleashed in a 21 F150.
I've been told you can just splice into the wires for signal. I've been told you can get the Sound Good Stereo wire adapter from the BO Amp into a new Amp and sub.
I've been told the only way to add an amp without endangering the amperage of the BO system is the Zen module with a new 12 channel Amp.
Any guidance/clarity you can provide would be greatly appreciated!
