Atlanta to Las Vegas
Sezary
Kathleen, GA
Hyundai Ioniq
My wife and family moved to Vegas for work and took the lightening (Lariat ER) and our second car(Tiguan) across the country.
We drove South to Destin to visit friends and family so we took I-10 all the way to Phoenix then hitting HW-60 to 93 to Kingman and then to Vegas using the trip planner in the Ford Pass app and ABRP for cross check with Plug Share to see the health and state of the EA chargers.
Leg 1: ATL to Destin
No issues with the network or charging along the way.
Leg 2: Destin to Lafayette
EA only had 1 charge location in Pensacola, this was my first time having an issue with EA since taking delivery of the truck. The EA station locked out and the cable got stuck in the lighting. I used the manual disconnect pulley inside the frunk and called EA. I had to charge there to start our leg so that added about an extra 2 hours.
Lessons learned, if plug and charge doesn’t work activate the charger from the Ford Pass App, no dice? Activate from the EA App. No dice? Hail Mary to EA tech help line. If I had checked Plug share I would have seen the issues at the station ahead of time and could have planned to avoid this
Leg 3: Lafayette to San Antonio
Averaging around 1.8kw going 65-70ish, 1.4-1.6kw when doing 80mph trying to keep up with the wife. No issues with charging.
Leg 4: San Antonio to Van Horn
If you find yourself in Van Horn eat at Moms kitchen.
Leg 5: Van Horn to Phoenix.
The cold weather hit us the morning we left. My range at 80% dropped to about 170mi from 250mi. None issue, trip planned added one additional charging stop. I will say today I started charging to 80% regardless of what trip planner said. Not due to weather or driving habits but with three kids charging for 18 minutes or from 23-67% wasn’t enough time to get out and change diapers and stretch legs.
Leg 6: Phoenix to Las Vegas
I do NOT recommend HW-63 to 93 to Kingman from Phoenix. There is only one charger between PHX and Kingman in Wickenburg at a Ford Dealership that is broken a capped at 22kw. This was my first non-EA charger I was routed too. I figured it being at a Ford Dealership it would be fine but it was an AWEFUL POS. Plug share did mention this but avoid this charger at all costs unless you must use it. I don’t know how Jones Ford of Wickenburg can be EV certified because their 1 charger is atrocious.
This drive already stretched the trucks range to its limit due to below freezing weather and I rolled into Kingman with single digit range.
Overall thoughts:
EA network worked fine, but not the reliability I expected to see. Ford Pass Trip planner was rock solid and minus the 1 non-EA charger was always within 1% of the estimated charge state rolling up to EA chargers. Speaking of charging, I do not know what it is with VW I.D 4 drivers….but they love to take 350kw stalls…that they can’t fully use….and charge to 100% ?. Nearly every single time I rolled up to a EA station some ID 4 is sitting there charging at 74kw to 118kw (max)on a 350 stall.
edit 1; corrected I-5 to I-10
MacMike
Mac
Mustang Mach-E
I-5? I'm sure you meant IH-10. Good write-up of your trip.
trev5150
Banned
Banned
Banned
Trev
Pilot of pilotless things
THIS is good HUMINT. I am going to Vegas for NYE (got a ticket to a thing) and WIckenburg is a key stop from here in Tucson. Will have to re-plan.
Edit: Looks like Tucson, Casa Grande, Phoenix, Quartzsite, Parker or Havasu, Bullhead City, Henderson, LV.
AZT9
Peoria, AZ
Overall thoughts:
Okay so it’s not just me. I’ve learned to cringe when I roll up to a charger to see and ID4 for the EXACT SAMER REASONS!! Come on people! Furthermore. The kias and Hyundais literally ALWAYS charge to 100% regularly regardless of the line of EVs waiting to charge! Let’s be curtious to our fellow drivers!
great write up. Thanks??
Oafy44
Georgia
23 ford lightning
Landscape contractor
Overall thoughts:
I’m a north Atlantian- marietta in particular. What route did you take to get to destin from Atlanta ?
We go down to 30a about 6 times a year and I usually take 1-20 to Montgomery then head south thru Troy - then go to Defuniack springs which will take you to 331 and eventually to 30a. If I were to use the lightning the way it looks is I go another way due to more chargers available ?
Sezary
Kathleen, GA
Hyundai Ioniq
I tried not judge to harshly at first but every single ID 4 driver was clueless about charge speed and battery health. It seemed all VW dealerships are telling people to just “charge to 100%” no matter what
Sezary
Kathleen, GA
Hyundai Ioniq
Here is what the trip planner is saying for your start point. Auburn and Chipley EA stations.
We took I-75 south through Cordele (visiting friends) then cut through Albany to Chipley for the final charge.
I’d would feel very comfortable making the trip via the recommend ford route. There aren’t any other routes using EA that I see that would add more chargers without a significant drive time increase
Ford F-150 Lightning Atlanta to Las Vegas AD37C8BF-42F1-458F-B0BD-F1E348106FE4
Oafy44
Georgia
23 ford lightning
Perfect. Thanks so much. I like the auburn stop and have actually seen the chargers there. Tons of restaurants ect. They have built that up nicely.
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
This app looks nice. Is this the Fordpass app?
ChrisInVegas
Las Vegas, NV
2022 F-150 Lightning Lariat ER
Former resident of GA and current resident of LV. Welcome to the dry heat! Hope you like it here. (We love it)
The stretch from Phoenix to Kingman is rough because there really is nothing between. We have made that drive a couple times in our ER Lariat, but it is a good idea to find the last charger in Phoenix and charge to 90% and then don't be a speed demon. For us, both trips along that leg were in the summer, so maybe in the winter even that won't work.
JIMINGA
JIM
ATLANTA
2025 Lightning Lariat (Rapid Red)
Acute Inpatient Psychiatric Social Worker (VA Hospital)
It is, you can send the route on your phone to your truck and you’ll find it under navigation, my trips, ford pass
Older GA resident (Lawrenceville), new '24 Lightning Lariat ER owner, question: precisely how do I send a route on my phone...to my Lightning truck...then find it under Navigation, My Trips, Ford Pass?
JIMINGA
JIM
ATLANTA
I use a fairly new iPhone, but am NOT smart/tech savvy at all...smart enough to retire from the military, but not smart enough to hang with technology, but love the benefits of tech in the Lucid and Lightning I drive. I still cannot figure out how to setup the voice command button to push it, speak who I want to call, and have the truck/bluetooth make the call. Then I try using Siri, and she tells me some other reason she cannot complete the call. If I stop the truck, pick up my iPhone, go to my contacts, find the person I want to call, press it, then press their number, it'll connect on my truck speaker fine, but that seems really antiquated/old school. Advice? Thread elsewhere that already addresses this?
