Blue Cruise and User Profiles
lightningforum6
United States
F-150 Lightning Lariat ER
Does anyone know if there is a way to turn Blue Cruise on or off based on the user profile? We have profiles set up based on the key fobs and for one profile Blue Cruise works as it always has. However, for the other profile, Blue Cruise has recently not been engaging when on the highway and cruise control is activated. I have checked the driver assist settings for both profiles and they seem to have the same options selected. The only difference between the profiles that I am aware of is that one has one pedal activated and the other does not. I have tested and confirmed that Blue Cruise working is tied to the profiles. While driving down the highway, if the profile is switched while cruise control is activated, then Blue Cruise will either engage or disengage based on the profile selected.
Yes, it is tied to the profiles.
No, you can't untie it to the profiles.
Check lane centering on the one that isn't working, the button on the steering wheel...
Amps
Mid-Atlantic
Bolt
Any chance you have PaaK(s) set up, too?
