ktn
MN
2023 F-150 Lightning® LARIAT ER
Just got an OBDLink MX+ coupled with Car Scanner Pro.
The Lightning works right out of the box with several standard dashboard pages I thought I would share here.
The HVB SoC numbers showed in the first page seem reasonable, just after charge completed at 80%.
The 95 kWh energy could refer to either a usable or stored figure possibly derived by the nominal capacity (131 or 143) weighted by a temperature factor (battery temp was 59F and typical nominal temperature is 20C/68F).
Very impressed with both OBDLink and Car Scanner, quite fast and reliable.
Of interest on the third page note the 12V battery reset days field, as 6 days ago I had the lightning serviced for CSP 23B70 with the LVB battery monitor sensor replaced and the BMS reset.
Also, in the same page the LVB 47 mA average quiescent current draw.
The truck was plugged to the charging station, and with accessory turned on the LVB was being charged in bulk mode at 14.8V.
The charge station was providing around 490W which would fit the power provided to the LVB of DC-DC LV of 28A * 14.8V (plus some power loss along the way), through the HVB with DC-DC HV of 1.2A * 377V, more or less ... :)
Can you share the backup for this? Thanks!
COrocket
F-150
For those of you using the OBDLink MX+, does the automatic sleep function work well? Are you comfortable keeping it plugged in all the time without draining the 12V battery even when the truck has to sit for a few days? Just got one and learning the ropes with it and Car Scanner
