Charge rate and finish time prediction gone after changing privacy settings.
cloudSurf
US
F150 Lightning XLT Sandard
A couple of weeks ago I was fiddling with the onboard privacy settings in the truck and turned most of them to conservative (don't track me around and send the data to Ford) settings. Since then I have lost my visibility in FordPass to see the rate of charging that I am charging at and the predicted charge finish time in the app.
Could someone fill me in on the minimum settings needed to transmit this data to the FordPass app so I can see that again?
I have since turned more settings to give Ford visibility but still I don't see the readouts on charge rate or charge finish prediction.
Thanks!
Thanks!
You might need to stop the current charging session and then start a new session to see the restored approved parameters, I haven't dug deeply into what the minimum level of communication would be needed (which switch to turn on) to return that functionality alone.
Trial & error one setting at a time until you find it, let us know!!!
BTW, if you're truck reaches it's goal SOC some of the prediction and rate information is suppressed until the charging current flows again.
priceb
Price
Western North Carolina
2023 F150 Lightning XLT SR
College Instructor
Privacy Settings:
I was only able to disable 3 of the Privacy Settings before losing information in FordPass:
  • Share Vehicle Analytics
  • Share Media Analytics
  • Speech Recognition Feedback
Feature Settings:
You could disable "Ford Assistant" and "Upload Contact Names" if you were not planning on using the ford assistance.
Disabling "Connected Navigation" will disable traffic information.
Disabling "FordPass Power My Trip" will prevent FordPass from sending routes created on the phone app to the truck.
Disabling "SiriusXM with 360L" will prevent SiriusXM's connected features from working, including the ability to listen to high numbered channels.
