Check and verify your tire pressure.
Skidrowe
Gideon
2022 F-150 Lightning ER, 2014 Honda Pilot
Yes, oxygen is 80% nitrogen but not 100% nitrogen. Nitrogen is an inert gas that displaces less denser gases like oxygen that creates moisture. Moisture is what heats a tire…. Remember oxygen adds fuel to a fire… nitrogen extinguish fire.
Argon is the best but too expensive for a non industrial application. Aircraft tire are inflated with argon.
This is some epic level trolling!
inchman254
Collingwood, Ontario, Canada
F150 Lightning Lariat, Kia Telluride
It still fluctuates, just a little less.
All of the aircraft I have worked on use nitrogen. The reason being the immense heat differential from cold to touchdown. We still need to adjust it for colder or warmer ambiant temps.
You're right... it still fluctuates. The reason for the nitrogen in aircraft tires is not due to pressure changes caused by temperature. That's going to happen anyway.
One reason is for dryness. The constant condensation due to the humidity along with the oxygen in air can cause wheel corrosion.
In addition, if a hot brake gets retracted, it could cause a wheel well fire. If the temps get too high, the fuse plugs will melt, filling the wheel well with pure nitrogen to prevent or extinguish a fire. The wheel well is not pressurized, but sealed well enough that the nitrogen will remain for quite a while.
Finally, an oxygen molecule is (slightly) smaller than nitrogen so 100% nitrogen leaks less quickly than 80% nitrogen (air). At aircraft tire pressures (up to 200 psi) this does make make a slight difference. Not so much at 40 psi.
SpaceEVDriver
Arizona
Thank you for the chart. Forgive me if this a dumb question, but would it be reasonable to expect the same pressure in all three examples? I realize they are close, but I was thinking the equations should get you to the exact pressure?
Not a dumb question. The reason they don't intesect is because the different temperature of the tires.
It doesn't matter which gas is used, the temperature and volume of the gas determines the pressure.
