Status
Not open for further replies.
abd79
Wayne
2021 F-150
I’m not going to parse all of this, but you need to realize that something that might seem trivial like the “odd space between characters” might be enough to knock out the whole module if you ever needed to download the as-built data to reprogram your module. It might be enough to throw off the Ford updating systems and disqualify you for future OTAs. That’s the point. It’s a corruption, and even though it might not look like much to you we have no idea what it will do in practice.
Agreed, you make good points. Question, has anyone with corruption using a nano or other alternatively gotten access to a VCM2/3 and re-did a network scan? Did it correct the corruption issue?
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
Yes, with the Nano. Corruption remained. I thought the rescan fixed things when I saw that the FDRS summary screen came out clean, but @iceman77 dug deeper into the code and found other corruptions. @Bob_Mac rescanned with a Mongoose and also had corruptions. @Jesse-Infotainment always used a VCM3, which doesn’t use J2534, and never had corruptions. I don’t know of anyone who got corruptions with a Nano and subsequently fixed them with a rescan using a VCM2 or 3. But I think it would work because it would read the local data, which is uncompromised, and then reload it to the server.
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
I will let you know as soon as my vcm3 finally shows up. Its on a tour with fed ex.
abd79
Wayne
2021 F-150
antho
Anthony
Houston, Texas
2021 801A Raptor
Yeah, Looking at the ASCII and hex, that one space throws it all off by placing a 20 in the HEX.
CORRUPT
ASCII = ML3 T-14H099-AF
HEX = 4D 4C 33 20 54 2D 31 34 48 30 39 39 2D 41 46
CORRECT
ASCII = ML3T-14H099-AF
HEX = 4D 4C 33 54 2D 31 34 48 30 39 39 2D 41 46
JEB
Northern Illinois
Is there any difference in the Mongoose-Plus vs the Pro Ford? Ford does call out the Mongoose adaptor as supported however I don’t see the Mongoose-Plus on the DrewTech site, I only see the MongoosePro Ford. These are the adaptors listed on Fords site as supported.
https://www.motorcraftservice.com/Diagnostic/FJDSSupport?categoryId=247
Mongoose Pro is no longer in production. It was replaced by the Mongoose Plus. Drew Tech was acquired by Opus. The Plus is on Opus’s website. https://www.opusivs.com/products/j2534-pass-thru/mongooseplus?hsLang=en
JEB
Northern Illinois
CORRUPT
CORRECT
You coders scare me.
TJSparky
WA
2021 F150 XLT (302A) RockyRidge K2
Just wanted to chime in on the suspected corruption of Software P/N in FDRS. I can say without a doubt it is not adaptor related. I have tested this now 12 times in the following manner;
1. No adaptor connected to the computer
2. I Deleted the vehicle profile in FDRS and restarted FDRS
3. I Re-entered VIN number and downloaded vehicle information from Ford
4. Every time I do this the part number for the APIM changes, It is always one of the following for me;
- "ML3T-"
- "FFF1-14D358-FF"
- "MU5 T-14G676-EJ"
So I believe we are chasing ghosts here and the problem is actually either FDRS or on Fords Servers not the VX or other adaptors.
So are you saying that "FFF1-14D358-FF" is a corrupt APIM. That is what I show for mine and everything has been updated to the latest info and no additional updates available. Shows Sync 21281 Rev 244
F-150 2021, Feb '21 build date, XLT 302A, 5.0L, 8" Cluster, Sync4 12" Screen
abd79
Wayne
2021 F-150
Not saying anything other than even when you don’t do a network scan and are completely disconnected the FDRS program is showing different PN’s for at least the APIM. I’m not sending them anything when this happens. Could be a result of a corrupted PN being sent to Ford from a bad scan who knows.
I’m trying to setup my Wireshark to capture the usb traffic on a network scan to help see if it shows anything.
JEB
Northern Illinois
NO! Your APIM is not corrupted. The APIM is fine. The back up programming data stored on the Ford Website is corrupted.
TJSparky
WA
OK! I haven't been doing network scans since my last updates. Just been seeing what comes down from Ford's servers first.
abd79
Wayne
2021 F-150
2nd the “Not Corrupt” message.
Software sucks! I diagnose it everyday, Communications is 4 times as bad!
FYI my Sync is at 22028 rev 358. Was the last update I did last night.
TJSparky
WA
Whoa! That is a new one! Does anyone have any additional info on what 22028 Rev 358 is? I thought 21281 rev 244 (OTA 2.3) was the latest.
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
CORRUPT
CORRECT
The 20 is a HEX value for a space so yes, this complicates it.
Status
