SeanOC
LINY
‘18 Raptor ‘21 Tesla Model Y
Pilot
Lightning specific?
It does list Lightning, but I would call or confirm before buying. The specific one has been there I believe about 2 weeks. I figured they just added Lightning to the list - I wasn't sure it truly had the updated harness for plug and play.
cvalue13
Austin, Texas
‘22 Lightning ER Lariat
Fun-Employed
the lightning-specific wiring harness is the key
If someone calls Putco, report back!
pstansel
Paul
Tolland, CT
Ok .. I ordered. The instructions it references don't give any indication that it is for the Lightning :( I asked for accurate instructions or my money back.
pstansel
Paul
Tolland, CT
And they sent me to... The old video that shows making it work through hacking the wiring. Doh. Refund time.
gg1919
Geoff
Chicopee, MA
2022 Lariat ER - Star White Metallic
I just installed mine today. Thank you to @Intellibeam foe the install video, it was very helpful.
I want to talk about one thing though, the light up sequence. I bought mine directly from Ford (obviously made by Putco though), and I noticed the wire loom was kind of crushed/suspect. I have plenty of loom, so I replaced it. In doing so I noticed inside the loom there was a green wire that was either a) broken, or b) cut. Tbh it looked more cut, as the “break” was in a spot in the loom that looked undamaged. I connected/soldered/heat shrank the green wire and I have the startup sequence. (Tested it on a spare battery first to make sure I wasn’t going to fry something)
Had I not taken the original loom off I would have never known and just assumed it didn’t have the sequence.
So, @Intellibeam , do you remember seeing a green wire? If so, it’s possible it’s broken/disabled inside the loom.
gg1919
Geoff
Chicopee, MA
Oh, and this was not lightning specific. I ran the wires like in the video, it wasn’t bad at all.
F150ROD
U.S. Navy Retired
Yeah the install isn’t bad at all and there is no “hacking” just grounding Nd taping into a fuse. I didn’t not notice a green wire but wasn’t really looking for one.
jpepper07
Joshua
Ohio
2013 Ford F150
Which one do I want if I buy from putco for my lariat? Do I want the wire harness? I want the led one right? why would I want halogen? If I go with fuse option then there is no halogen option.
SmokingtheMeats
PA
2010 F-150
Tech
I talked to Putco on tuesday and they do not have the light with the proper 10 pin plug yet. I figured I would just wait until that is complete.
LED is what you want.
jpepper07
Joshua
Ohio
2013 Ford F150
Thanks! I will wait then.
teaguem32
mike
arizona
ER LARIAT SQM
So I did the install. pretty straight forward. Fuse 48 did not work for me for some reason. No power. I ended up using 181. Works fine. This morning my turn signal are flashing fast like a bulb is out, but both. No signal lights in the front, on in the rear. What the heck?
drag0n
Kevin
F-150 Lightning Lariat SR
any update on this from Putco? or still no quick connect?
Simpso57
Rob
Ford F150 Lightning
What if I just want black emblems front and back? I don't need it to light up. What are my options?
