FCSP Lights Issues
9onmy6
Greenbow, AL
BMW M2, Ducati MTS 1260, 2023 SR Lightning XLT
Housemaker/Veteran
I just wired mine up today. I was having a heck of time with all the WiFi setup.
After performing step 8, everything connected.
The Weatherman
Dean
South Central KY
What @Hellian said. Mine did the same last summer when it was pretty hot 90’s in KY.
I went through the same steps as he did but had no luck. I reset the system several times by switching the breaker off and as using the internal reset key. The issue with mine was that the system was showing the full blue bar, but the FordPass was always showed it was changing at 9.KW even though the dial was set to 80Amps.
After several attempts to change the output dial and resets I finally landed on 6 (64Amp) with FordPass showing 13.KW. (Felt like I was back in Vegas).
I subsequently added a multimeter to keep an eye on what the unit is outputting.
Old Aviator
Larry
WPB, FL
Consultant
Glad I could add to the knowledge base, unfortunately the downside is that if you a are a member of PETA you may forever be locked out of access to your FCSP.
9onmy6
Greenbow, AL
Housemaker/Veteran
P = People
E = Eating
T = Tasty
A = Animals
