Ford Perimeter Plus Security System
Jesse-Infotainment
Jesse
2024 F150 Lightning Platinum
7D0-09-04 xxx* xxxx XX--
The first Octet needs a 1 also where the astrick is. I just added this to my flash
Linbus initialization is also needed
Jesse-Infotainment
Jesse
Under the wrench icon in Forscan. Select this option
Ford F-150 Lightning Ford Perimeter Plus Security System 1738633816044-wn
Interesting. I see that the 2024's have a 1 there but all the 22's and 23's I have looked at (7 from each MY) have a 0. Same with the few ICE trucks - only 2024 has a 1. So 2024 seems to be different. I'll look at Livnitup's spreadsheet to try to understand the difference.
Good to know the Flash can add this. I added this to my post above.
Jesse-Infotainment
Jesse
Well. Let me add some details about the FLash.. I added the wiring for it..
Also the over head console doesnt have the cutouts for the sensors.. I added them as well..
So its much more involved than jsut adding it to a truck that has the blank..
Ford F-150 Lightning Ford Perimeter Plus Security System 1738670770707-gk
MJFlanigan
Michael
Atlanta, GA
2023 Ford F-150 Lighting XLT
What other wiring would I need to add for the xlt and what cutouts or where do they go. I guess I just drill it out?
Jesse-Infotainment
Jesse
Three wires. Power, Ground and lin bus
power Pin 15 C2280C
Lin Bus - Pin 36 C2280E
These are at the BCM.
MJFlanigan
Michael
Atlanta, GA
power Pin 15 C2280C
What wiring should I use and do I need to run them from up at the top? Any other photos you can share. The bcm and other pieces make sense. Still confused on the linbus a little
Jesse-Infotainment
Jesse
Ford F-150 Lightning Ford Perimeter Plus Security System 1738779012997-5d
mrau
23 Lariat⚡ER
Added the Security Pack to my '23 Lariat today. Thanks to everyone for postings here and on the Gen 14 forum.
Overall it went as planned. I did have the factory blue dummy box that was connected to wiring harness, but no pins or leads in the box. I also had to remove the back cover of console after I had it out. It was only way I could get the sensors into position, The middle sensor was the most difficult, just took some finesse.
A big thank you to @bmwhitetx for all the FORSCAN info. Made that part a lot easier.
Before disconnecting FORSCAN I did a BCM LIN Module Config using the "wrench" icon on left side of FORSCAN screen. Then I cleared out the DTCs and all was good.
Tested the motion alarm by waving my arm through the open window. Horn sounded and I also got an alert on my phone from Ford Pass app. (nice surprise).
Here are some photos I took. All in all it seemed a worthwhile project.
Ford F-150 Lightning Ford Perimeter Plus Security System IMG_3206
Ford F-150 Lightning Ford Perimeter Plus Security System IMG_3207
Ford F-150 Lightning Ford Perimeter Plus Security System IMG_3215
Ford F-150 Lightning Ford Perimeter Plus Security System IMG_3209
Ford F-150 Lightning Ford Perimeter Plus Security System IMG_3211
Ford F-150 Lightning Ford Perimeter Plus Security System IMG_3214
Ford F-150 Lightning Ford Perimeter Plus Security System IMG_3220
Ford F-150 Lightning Ford Perimeter Plus Security System IMG_3219
MJFlanigan
Michael
Atlanta, GA
What did the harness look like on the inside?
mrau
23 Lariat⚡ER
There are 3 separate harness to unclip from the console. One for lights, one for rear sliding window switch and one for the motion sensor.
Didn't get any pictures of the motion harness, but here is a photo of the blue boxes where the harness plugs into. The "dummy" blue box (bottom in photo) did not have any pins in its connector.
Ford F-150 Lightning Ford Perimeter Plus Security System IMG_3213
MJFlanigan
Michael
Atlanta, GA
This is helpful. I'm trying to find the harness part number or anything for the whole piece if it doesn't have the power or wires since I have a xlt ER lightning.
