Forscan ipc module
Millionvill3
James
2021 f150
Business owner
Was able to get into the ipc module the other night and it had about 100 options to toggle and switch. I changed a few options nothing major. Wrote the file and everything was fine. Woke up the next morning and a few different codes were lighting up the dash. Went back into ipc module and all options were gone.
Any Forscan techs out there that can shed light on updates and what not? I know its going to take some time....
Ajzride
Alan
Houston
Eng
I can’t help you with your request, but will warn you I learned today that forscan changes to the IPC broke an OTA update that I installed via FDRS. I had to manually undo my forscan changes to get the OTA to finish.
