Has anyone installed a heated steering wheel on a pro?
jdmackes
2023 F-150 Lightning Pro
Just wanted to clarify here too, you can have HSW on a pro with control via the 12" display without needing a new HVAC module but bear in mind it impacts the appearance of your menu/UI
source: I have HC seats, and HSW running off of stock pro HVAC controlled via synch UI
You can have it without changing the UI also, mine just comes on automatically (so I can't manually turn it on or off, but it hasn't been an issue so far).
lSherlockl
Wisconsin
F150 Lightning Pro 22'
interesting, mine i have set so it can come on with remote start/precondition based on outside temp. but i still have full control to turn it on or off via the synch screen.
and yes you are forced into the UI change but you get used to it. I have seen some reports of a guy getting a ICE module to work but haven't confirmed the part no he used, but im honestly fine enough with onscreen and no extra cost i already fought with the older HVAC module with the little lcd displays unsuccessfully
kstevens
Kevin
Vermont
2023 Ford Lightning PRO, 2015 Nissan Leaf S
jdmackes
@jdmackes really appreciate all this. gearing up to knock this one out just in time for summer ;)
to run the power from the BCM assuming you more or less followed what this guy did:
https://www.f150gen14.com/forum/thr...etrofit-updated-with-information.6022/page-13
also assuming that you just used two of the terminal wires from the WT1030 kit instead of the more expensive pre-built WPT404 pigtail?
As I remember I bought the pigtail. Not to say you couldn't do it using the terminal wires though, I just don't remember it being very expensive when I ordered it
