Headlight Protection Film
currybob
Bob
Alexandria Alabama
2021KRF150 PB; 2020 LexusRX350; 2021 Mazda Miata
Retired Physicist from federal government; Army Veteran
So did you wrap all around the edges of the headlights or just do the flat fronts section? Just wondering how difficult it is to bend it around the edges without wrinkles or relief cuts.
I just did the flat area and a small portion of a small bend. Covered about 90% I would say, if I had any skill laying this stuff you could easly do the entire front surface. All of the head light surface is covered.
Heavishot
Kerry
DFW, TX
2021 Platinum F-150
I purchased Lamin-X tail light tint which turned out nice. (Will make another post on that when I have more time. )
Also installed Lamin-X clear headlight film. I’m very handy with tools and craft type projects but this is not easy to install, at least not if you want it to look near factory quality. The real bummer is that it has a noticeable orange peel texture that I just couldn’t live with. Some people might not care, but for me it distorts the crisp, clean look of the 2021 headlights too much. Now I’m wondering if another brand might be completely smooth??
Ford F-150 Lightning Headlight Protection Film 3B24D9A4-6B23-4056-A2A3-80D079A28005
Airspeed00
Toronto, ON
2021 F-150 Lariat Sport 4x4 502 SCREW
Any updated pics of the head light / tail light install? Cheers!
Heavishot
Kerry
DFW, TX
2021 Platinum F-150
Haven’t tried the headlights again but here are the tail lights and cab lights. Only did the whites.
Ford F-150 Lightning Headlight Protection Film 312697F6-EFD4-48DC-B452-FE5C27BDC0E2
Airspeed00
Toronto, ON
Thanks! They look great w/ only the reverse done. Now I can place my order. Cheers!
Airspeed00
Toronto, ON
I second that the lamin-x stuff is not easy to work with. I just did the whites on the rears. Not a perfect fit on the inside bottom corners of the BLIS, but I bought some extra to cover any spots that need it.
The headlights were tough to install as well, due to the channel between the large flat part, and the LEDs that surround it. I ended up cutting in the middle of the channel, effectively making it 2 pieces. That helped considerably. I'll post a pic in a couple days once the solution/ any small bubbles have cleared up.
