Horn Sound Change After Service
Meddle
Bill
Has anyone else had the sound of their horn change after having the CSP service for the front sensors done?
Heliian
The CSP was just an update no?
The horn is the horn, it runs off 12v hot all the time.
Unless they tore apart the front end and didn't reseat a connector, I can't see how the 2 are related.
queuewho
Western PA
22 F150 Lightning Lariat SR
Pretty sure our horns are two tones combined, so if one failed, got disconnected, or something got jammed in it, could be why it sounds different.
Ekiehn
Eric
2023 F-150 Lightning Latiat, 2008 Ford Explorer, 2006 Ford Escape Hybrid
Check your LVB when some CSPs that take longer to upgrade are run the 12v battery gets drained... yes the should be putting a charger on it when doing the CSP but if your battery can't hold it SOC then weired things start happening.. everything sort of goes into "limp" mode... I could see that "half" the horn would play...lol my auto door locks would work for the driver but not for any other door, my internal chimes didn't go through the sound system, mistress wouldn't acknowledge me when I walked up to her (she really developed an attitude)... I have found that almost everything that ends up not working from OTA updates to the smallest thing often revolves around the LVB or resetting the system by same...
Meddle
Meddle
Bill
Thank you so much!
