How’s your Lightning doing in the cold?
meow
2022 Lightning Lariat ER; 2024 Hyundai Ioniq 5 SEL
If I could just learn to keep my foot out of this thing, I could get a lot better range. I love driving this truck. It is by far the best truck I’ve ever owned!
Every EV-owner I've met has tried to tell me "it never gets old". It did get super old the moment it dropped below freezing here. 1.1kWh/mi on a few trips and I'm hoping for warmer weather like I never have in years past.
FordLightningMan
Upstate New York
F150
Really, you didn't see a topic on winter range of the Lightning? It's like every other thread, but in any case, 1.6 seems like a very common number or about 30% range loss until you get into much colder weather where people are reporting 50% loss.
For people without heated seats, the average seems to be closer to 1.3 mi/kwh in the cold. This is the number I use when planning my drives now. So I'd say 1.6 Lariat/Platinum and 1.3 Pro/XLT are the most common responses to "what's your winter range?" Though I too have seen as low as 1.1 mi/kwh when making stop and go trips around town with shorter drives.
@SmoothJ
Those extended warranty guys are persistent !!!
Ford F-150 Lightning How’s your Lightning doing in the cold? 1672157956286
GFreud
Gerry
23 F 150 Lightning
I agree also, had a 90 mile trip in -5 degree temps, took 180 miles of available.
Driving slower helped, unfortunately it took 15 cars in a ditch to slow us down. The tried to charge on a 110v outlet and it actually lost charge sitting outside because of the low temps.
Howard S
Howard
2022 F150 Lightning Pro
Have no real complaints. I knew it would be an electron hog. Yesterday coming up the hill to Mammoth Lakes, which is the ski resort here in California had probably the worst combination of weather, elevation, and speed. I drove 40 miles from Bishop to mammoth lakes and it’s an elevation gain from 4100 feet to a little over 8100 feet in approximately 40 miles. I was driving with a warmed up cabin, kept an average speed of about 67 miles an hour and the temperature varied between 26 and 40°.
I used 1.3 miles/ kW. In retrospect my mileage since the truck was new after almost 5000 miles is on spec. My average for that time which includes a lot of highway driving and not too much cold weather so far is 2.3 miles/ kW. Biggest problem is the electric charger infrastructure which still sucks. Just make sure you don’t let SOC get low and charge more often. I’m used to a Tesla for the last five years and I never had to think about it. With CCS charging, you have to overthink it because on average between 25% and 50% of the Electrify America chargers will actually work at any given time and I’ve even had times where none worked. Just enjoy the truck and stop reading this 😊
Here is what my Lightning has done up the hill about 37 miles 4000 ft elevation gain with 28 degree temp and ave 67 Mph When I said 1.3 kWh/mile, that is when I took the turnoff to town. I gained a bit in the last 4 miles
Ford F-150 Lightning How’s your Lightning doing in the cold? 1673069915174
Down the same hill in about 40 degree weather :
Ford F-150 Lightning How’s your Lightning doing in the cold? 1673070112529
not too bad if you average it out. So far since new 2.3 KWh/ mile. 5,000 plus I did add a hard bed cover and Ford running boards.
