p52Ranch
Bryan
OK
Did you notice a ride quality difference with the E rated tires? What inflation pressure are you running?
romeoz
21 Telsa Model 3, 18 Ford Raptor 22 Ford Lightning
45psi and the ride quality is the same to me.
Artificial Intelligence
Looking
with Leveling kit your sensors are not pointing where they were originally designed to point. A small deviation is amplified at higher speeds. No manufacturer in their right mind will take on that liability. That said, i dont think it will stop people from using the kit anyways
tango
Norm
2016 F150 Platinum, 1962 Thunderbird, 2019 Ram
I doubt it makes a difference, reason being with a full load in the bed, the truck would be “level” and presumably Ford would have tested Blue Cruise under these conditions.
I think this might be where it gets wonky. I agree that it is probably within tolerance because it is similar to a loaded factory setup. My guess is that it might get out of tolerance with the level kit AND a heavily loaded bed.
Fast150EV
Matt
Austin, TX
2015 F150 Lariat, 2022 F150 Lariat EV
Any decrease in charge range after adding the lift and tires? I have same 2" leveling and similar tire combo on my 2015 and I lost an MPG - wondering if the same will happen on EV. Also - I had to do alignment on '15 after install - same on the '22?
T i h o r
Rohit
Toronto
F150 Lightning
Self Employed
BlueCruise is working well. Driven about 100 miles total with BlueCruise after the leveling kit was installed and not a single issue. Honestly, it seems to work better!
Got any pics/vids? I think there may have been some posted before, but nothing is showing now 😭
