TruckGuy2020
Nick
North Carolina
2021 F150
Military
Have any of you with the Leer HF650M experienced water coming in between the panels where the hinges are located? I was checking for leaks following a pretty hard rain and noticed some drips coming through between each panel. I expect some water at the extreme ends but I had hoped the mid-section would be fairly water tight. Not sure if mine is defective in some way or if this is common.
Exact same issue with me, 5 months old and it developed a few "hot spots" along the folding seals, essentially leaking/dripping right in the center of the bed. I contacted LEER and they sent a replacement under warranty. New one has been on for 1 day and same exact issue, it still leaks (very slightly albeit) along the folding seals near the center. I'm at a loss at this point, I don't think LEER will give a full refund for warranty, but obviously getting another replacement will likely be the same issue and I regret purchasing this model. Highly disappointed, especially for a $1,000+ cover. Do not recommend buying this one if you're going for high-quality waterproof.
JoCox32
Ohio
2021 F-150 XLT
Civil Engineer
That's frustrating, sounds like I might be in the same boat as you then. I will try to warranty claim my cover on that same basis to see if a new one fixes the issue but I am skeptical after seeing your experience. Did you have to pay to ship your old cover back? Or did they tell you to keep it?
Bbass5
Bbass5
Birmingham
F 150
Leaning towards this cover. Has anyone driven with just 1 section opened? What keeps the wind from blowing the section closed?
You are correct, if you drive with one section open, the wind will blow it closed. You’d have to strap it down some way to keep it from blowing over.
That’s the one con I have. But once you open the first panel, the second panel isn’t latched. And by the time you flip that’s second panMel, you might as well flip the third. And thethird panel has clips to lock it down to travel. So it’s either:
  • Fully closed
  • Partially opened with the last panel clipped down
  • Fully open with the prop rods holding it up
magvallo
NE
2021 Lariat Sport PB
I haven’t had this issue yet but my old trifold gaskets would slightly shrink in very cold weather. I definitely had more water in the winter months. I really like the leer over my previous cover. I knew I would have to deal with some water hopefully not a major defect.
TruckGuy2020
Nick
North Carolina
2021 F150
Military
they did not ask for the old one back, still trying to decide what to do with it, it’s sitting in my garage. I’m evaluating the new one to see which one leaks less, then probly sell the other to recoup some of the cost I lost in a $1k+ cover that can’t even keep out rain.
ISLANDF150
Kyle
Ontario, Canada
2022 Ford F150 XLT FX4 3.5L Ecoboost
On autoaccessoriesgarage.com it says the leer HF650M is not compatible with drop in bedliners. But on other sites it says it is compatible. Close to pulling the trigger on this while I wait for my truck but I'm getting a drop in bedliner so want to ensure it will work. Anyone have any knowledge/experience with this?
Raicilla
Rudy
Upper Left Coast
2021 F150 Lariat SCREW AMB 157" PowerBoost 7.2kW
Outstanding write-up! I'll be adding the Leer to my PB, me t'inks...
I see your "fully-folded-open" photo with your 5.5' bed. BIG Thanks:
Ford F-150 Lightning Leer HF650M Tonneau Cover Review with Photos! - Install & First Impressions img_6468-jpe
The brake light (and camera) are still usable (as you note). The "quad-fold" really looks like the way-to-go.
Does anybody have a similar photo of the Leer HF650m on the 6.5' bed? Specifically, how much "taller" are the fully-folded panels? Is the cyclops still visible and is the bed camera still useable?
Other thoughts?
Thanks in advance: :D {this forum is so helpful!}
TF1000
Ted
Wisconsin
2018 Prius Prime, 1996 Ram 1500
Can anyone who owns the leer 650 confirm where it's made? Getting conflicting info on whether it's China or USA. Will go with Bakflip mx4 if the Leer is Chinese made.
Thanks
Azpt22
Gilbert AZ USA
2023 Lariat ER
What an awesome write-up, thank you!!!
I think I am going with this one over the BAK x4s.
UWdave
2023 Ford Lightning Platinum
I've decided on this cover. Looking at places to buy from, Amazon has the best price (plus 5% off with Amazon VISA). The only problem is they are saying it won't fit the Lightning on Amazon fit guide. "HF650M" is a model that comes in various sizes.
It says it fits 2015-2024 Ford F150 w/ 5'6" beds
https://www.amazon.com/LEER-HF650M-Quad-Folding-Profile-Tonneau/dp/B082FMG6QK?th=1
Can anybody confirm this will fit? Thanks in advance.
Amazon PN: 650112
Amazon UPC: 812227028725
Amazon ASIN: B082FMG6QK
