TRP
Tim
TN
2021 Mach E Premium 4X, 2018 Ford F150xlt Sport
Do you have any rear suspension pics? Looking for more detail about the frame rails vs the rear motor and what the rails look like over the wheels
BEVolution
BEVolution
Arizona
Model Y adding Lightning
JPro
Vancouver, WA
22 F150 Lightning Lariat SR
Rebar Detailer/Estimator
Ford F-150 Lightning Lightning Front Suspension Photos 5A6F1A85-EC75-40D8-BB84-191B956756B0
JPro
Vancouver, WA
Here’s a picture I took from above at the rear, not ideal but figured I’d share.
jefro
F150, Corvette, Bolt EV,
Not thrilled with half shaft at wheel.
BEVolution
BEVolution
Arizona
Would you rather hub motor with increased unsprung weight or something else?
Pedaldude
Arizona
He might be referring to the extreme half shaft angles, seeing as how the suspension is nearly at full extension because of the unladen frame.
WRS
Will
Mannford, OK
2018 F150 Lariat
Aviation
jefro
It appears to me to be an open point of dirt and water to enter.
BlueOvalF22
2010 Raptor Supercab FULL long travel build.
Technical Management
Looks good.
I like how the front drive unit drops in with what appears to be standard F150 A-arm points and the steering rack bolts. Because this will make it easy to convert my first gen raptor.
In the rear, I'll weld in a front cradle to hold the drive assembly and fabricate a multilink IRS.
