Lightning off-grid charging Solar Array Build w/Agrivoltaics
MurphysLaww
MurphysLaww
Austin, TX
2023 Lariat Lightning ER,Cayman,Q7 Overlanded
Systems Engineer
As one might expect, days are getting longer, and we broke another PV input record. I wasn't sure in the winter we'd get to 15kW, which portends to good output this summer.
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_9927.PNG
Working on the PA Hall sensor actuators
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics Screenshot 2024-01-18 at 12.18.00 PM
Have one moving as I would like with the motor drivers I've been using, and added a voltage monitor. Next working on syncing 3-5 of them. Wasn't sure I'd be able to use my dual h-bridge controller, but it looks like two of them might work.
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_9937.JPG
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
I had to read this a couple of times 😂. You produced 15kWh, I was like what kind of panels do you have producing 15kW and got massive panel envy. All of your info is awesome BTW. I'll try to get my system posted soon, but way more basic that what you're doing..
MurphysLaww
MurphysLaww
Austin, TX
Systems Engineer
Thanks, one of the things I'm doing is just checking to see if this is a viable way to do this.
I'm using the house as a control, which doesn't have tracking. While the tracking does provide more output, I'm not sure I'm going to get to the 25% additional I'd like to. We'll be deepening the angle of the panels from 15 degrees to as close as we can get to 25 degrees this weekend by moving to the 24" Progressive Automations actuators from the ecoworthy 18".
The charging system is 3600 watt, and the house 5400, or it's 66% of the house. So far, we haven't even produced 66% of the house output yet. If that is the panels being used, or the inherent increased loss of a dc inverter system vs. the house micro-inverters it will remain to be seen, but it may never be a perfect test environment due to the shadowing the powerlines above produce. I lose, I think 1-1.5kw a day due to this. There probably isn't a good way to configure the panels (series to parallel) to fix much, if any of that.
MurphysLaww
MurphysLaww
Austin, TX
Systems Engineer
Big workday. Probably the last for awhile. Looks like lot's o' rain and clouds for the next 8 days at least.
Got the Progressive Automations hall sensor linear actuators installed. I added another motor driver to the control box, and rewired the actuators with 16 gauge wiring, home runs to each actuator. When I tested the first one, it really didn't pull more amps than the ecoworthy, though. The main, noticeable difference is that these are nearly, entirely, silent. It's weird. You can really hear the ecoworthys when they are moving.
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_9957.JPG
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_9972.JPG
This, so far, with no tweaking, has resulted in an increase from 13.8 degrees early morning tilt, to 17.5 degrees, and from 15 degrees evening tilt max, to 23 degrees. We'll play with that, but I'll bet we'll see some increases in output, especially in the evening.
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_9948.JPG
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_9954.JPG
And the code adjustments( I know, ugly code with no comments...) and control box modifications. Still have to stack one more motor controller. These have two 8 amp outputs, so I need one more output for the 5 actuators.
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_9961.JPG
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics PXL_20240121_125552155
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_9967.JPG
MurphysLaww
MurphysLaww
Austin, TX
Systems Engineer
With the new actuators and angle, looks like another new record for generation. We’re at 15.1kW at 4pm, and the previous was 15.2. We even had 20 mins of no production while the truck was at the farm, and the batts filled up around 1:30pm.
***edit - finished the day with 16.3 kW, even with the loss of, likely, 0.5 - 0.75 kW when the batts filled. 17 kW in winter sun is a good sign for, hopefully, 20kw or more in March.
won’t hit quite 200kW pit in the truck for the month, but the truck was at the dealer for the first week, so I’d bet we might make 300 by next month, and goal of 400kw in March.
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_0004
Finished the introductory video for the channel. I’ll break each part of the install down into individual vids.
Free Fuel for your EV!
MurphysLaww
MurphysLaww
Austin, TX
Systems Engineer
Cool sunny days, and we broke an output record by quite a bit yesterday. We produced 19.5 kW, and put 55 miles back into the Lightning, at least according to FordPass. We hit 18.4 kW today as well.
I pulled two of the five, Progressive Automations linear actuators off the array, to work on testing the coding for the synchronization of the five actuators. Interestingly, the five of them are not as uniform in motor output as the cheapo ecoworthy, so, I'll definitely have to sync them for sure.
I, unfortunately, had a small accident with the SolarAssistant Raspberry pi, that pulled the microUSB connection port entirely off of the EG4 control unit board. It would be really fine soldering to fix, and I don't really have the equipment to do so. I have a new RS232 to USB cable coming from SolarAssistant, which hopefully will work as well as the direct to USB did.
Non-Lightning or EV content, but I'm getting closer to finishing our 2012 Audi TDi overland project as well.
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics PXL_20240210_211140064
Test fit for it's Wilco Offroad, swing out tire carrier on the Lightning, though...
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_0131.JPG
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_0130.JPG
MurphysLaww
MurphysLaww
Austin, TX
Systems Engineer
Making a tons of progress with raised beds installed, control box coding just about complete, and new records for output:
Crossed a signficant milestone of 20kw of output in a day on march 11th, and have been getting consistently high output and input:
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_0510.PNG
Control box now with an Arduino Giga R1 Wifi, and Giga Display in a case I found on Ebay:
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_0477.JPG
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_0509.JPG
Beginning of the bed planting fenced off from our Curious mutts:
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_0468.JPG
MurphysLaww
MurphysLaww
Austin, TX
Systems Engineer
Love the progress- your system is something to be proud of!
Thanks!
It's been fun, and fun that will pay for itself and provide backup power for the house!
The better I fine tune it, the quicker the payoff.
While I've been working on the coding to sync the actuators, I pulled two of the five actuators and I've been moving the panels manually throughout the day, so once they are back to automated function, the output should be even higher.
One of my least favorite parts of the project, making molex connectors...
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_0516.JPG
And the next project... Making at least some of this mobile with 30-40 flexible 100watt panels, and 10kw of batts, and a quick-disconnect system for the Hybrid inverter, or another one, to move to this trailer, which will be lifted a bit, and have a no-weld kit to build the frame up for Electric overlanding adventures:
https://compactcampingstore.com/collections/trailer-rack-kits
(need to finish the Audi Q7 overland conversion in the background first, though)
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_0513.JPG
MacLightning
Fion
2022 Ford F150 Lightning XLT
Really enjoying this thread, your YouTube channel, and all your cool projects!
Thanks for all the excellent details on your work!
MurphysLaww
MurphysLaww
Austin, TX
Systems Engineer
Getting pretty close to complete. Implementing some gutters to feed the rainbarrel in the foreground, moving the 100watt panel that powers the control box over to this side, and then getting the automated microcontroller controlled watering going, and then it's just waiting for harvesting!
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_0608.JPG
Producing more than expected. Hitting 3kW peak during the days now, and went over 300kW for the month with only sporadic use at times and lost the 100kW we put in with the chargepoint quick charger:
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_0615.PNG
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics Screenshot 2024-03-16 at 11.02.56 AM
MurphysLaww
MurphysLaww
Austin, TX
Systems Engineer
And broke a daily production record by over 10% yesterday...
That's the benefit of the automatic tracking which is just back up and operational.
Soon, we should have 20kW of batteries to max out.
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_0617.PNG
MurphysLaww
MurphysLaww
Austin, TX
Systems Engineer
Hadn't had much to post that was new, but started another phase of the project and broke another record for production.
Hit went over 24kw in a day for the first time, which at the beginning of the thread, I think someone mentioned they drove 48 miles in a day, which this would now cover(with some additional battery storage, as we only have 10kw, but soon will have 20kw.
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics Screenshot_20240519-175758
And now we'll use the rest of the output now, and I'll have a cool mancave, which will eventually pay for itself.
12k Btu Pioneer 23 seer.
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics PXL_20240519_225153571
And the Vegetables are a growin'...
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics PXL_20240514_201752670
MurphysLaww
MurphysLaww
Austin, TX
Systems Engineer
Updated content coming soon.
The mobile Lightning charging system for overlanding is in design phase, and the EG4 refurbished hybrid inverter failed, and has been warrantied by Signature Solar. We're going to move everything to a victron system, increasing the overall cost of the system by about 20%, but hopefully alleviating headaches as it did when we moved our art studio system from Epever, to Victron.
MurphysLaww
MurphysLaww
Austin, TX
Systems Engineer
Impatiently waiting on UPS for the Inverter/Chargers.
Already testing the charge controller.
Moving this build to a new thread, related to overlanding/camping
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_0994.JPG
Ford F-150 Lightning Lightning off-grid charging Solar Array Build w/Agrivoltaics IMG_0975.JPG
