Mirrors for those of us without factory Tow Mirrors
Orang
LT
ID
2021 f150 xlt 302a with tow package
Hawkeye
Hawkeye
2021 F150 STX
Military
Has anyone found them in stock anywhere?
aaron90245
Aaron
Boise ID
2021 Ford F150 STX 2014 Cadillac CTS-V
Pediatrics
Solved.
The YouTube vid of 2020 mirrors being altered a bit and fitting a 2021 stx xl (my case) is true. I had to remove more of the plastic structure inside the mirror mount on the driver's side but it's doable. I also used a uni-bit to enlarge the 2 most forward built holes in the door. Also had to make a small notch in the door (¼"x¼) for part of the aluminum rigidity thing. Passenger motor went on with very little alterations.
I don't have any gaps like the YouTube guy did when finished.
These have power mirrors.
https://www.topgearautosport.com/
Order Detail:
Ford F150 2015-2020 Towing Mirrors Power Heated LED Signal Puddle Lights (Item:A1280FAH221, Qty:1)
Ford F-150 Lightning Mirrors for those of us without factory Tow Mirrors 16227363558305005144927605360655
Ford F-150 Lightning Mirrors for those of us without factory Tow Mirrors 16227363800482830067211314772965
Ford F-150 Lightning Mirrors for those of us without factory Tow Mirrors 16227364060337360196146718059264
Ford F-150 Lightning Mirrors for those of us without factory Tow Mirrors 16227365886085785391254554563583
F150Eh
Canada, Prairies
2021 F150 XLT
There are no aftermarket "slip on" type tow mirrors on etrailer for the 2021. The only ones so far are the kind that attach via straps which I am leery of.
I tried to put on a K-Source model ( K Source :UNIVERSAL ) after verifying with an online website that it will fit on a 2021 F-150. Will it attach? Yes. Will it stay on? Definitely not! The way the stock mirrors are shaped the pads under the ratchets can't get a clean enough grip and they slide. Pretty sure a strong wind would send it flying. Took it back.
Sentinel1201
DFW
2021 F150 Powerboost
Solved.
Order Detail:
Do these have BLIS?
