MurphysLaww
- Jan 20, 2022
- Austin, TX
- 2023 Lariat Lightning ER,Cayman,Q7 Overlanded
- Occupation
- Systems Engineer
Starting the mobile conversion of our current off-grid charging system for our Lightning with the goal of WFC (work from campground) in the near future. Starlink standard kit and Roam subscription on the way. Fair warning, the trailer, if it happens at all, won't be purchased until next May, likely. We have a 5x8 trailer that was part of the original plan, but the limited size, and the increasing thoughts that I want to try to tow the Autocross car to events with the Lightning has changed the plans. I have an old Audi Q7 Diesel that I'm finishing up an overland build on(3" lift, swingout tire carrier, 2785/70-18 mud tires...
It's here:
https://www.overlandbound.com/forums/threads/2012-audi-q7-tdi-eurowise-build.48064/
Original Lightning offgrid charger build thread is here:
https://www.f150lightningforum.com/...rging-solar-array-build-w-agrivoltaics.17055/
The original refurbished, EG4 6000ex-48HV inverter gave up the ghost, and I wasn't inclined to give a Chinese manufacturer another shot at this time, so going Victron this time. This will add another year to payoff for the system, but if it's also Mobile, I'm good with it. We have victron in our 8x14 studio shed that has been working perfectly for a year plus. We'll likely also go with a Victron EVSE, if we don't use the spare chargepoint we have left over since we have the FCSP.
I expect to build an overlanding trailer out of a 5x8ft trailer we already have, with likely, 3000-4000kw of panels. That design is still WIP right now. It's not impossible that this might change to a Casita, or a used pop-up.
Starting with a Ryobi convertible workbench/dolly, which conveniently, should fit most of the components, but also should be pretty unwieldy. We'll see. It'll hold 400lbs, and we're only at around 200 now.
ON the bottom of the Dolly tray we have a 48v, 5kw Battery currently. We'll see if it works or if we need a second one. This takes the home system up to 15kW when it's tied into the system.
It's here:
