Premium Extended Warranty and module program updates
Status
Not open for further replies.
kcmarvin
Kevin
Vermont
F150
I got a "Shift Module Error" on my 2021 F150 Hybrid at 45,000 miles which has a Premium Extended Warranty. The dealer cleared the error and said that the module has an update that they believe may address the error BUT they said the Ford Premium Extended Warranty that I purchased does not cover module programming and I owe $189 for the programming. I contacted Ford Warranty and was told that their warranty covers module replacement but not programming. I argued that the programming is a component of the module and therefore is covered just as it was with the original warranty. Prior to the ability to reprogram modules, they were outright replaced and a reprogramming charge is significantly less. I argued that the shift module operation is part of the power train warranty but I got nowhere.
Have others experienced this same issue with the Ford Premium Extended warranty? Considering the number of modules, $189 each for programming when I expect warranty coverage is a significant issue.
While your vehicle isn't a Lightning (and therefore this is the wrong forum), you answer is applicable.
1) Module programming is not a per module cost, it's the dealership charging for a mechanic's time (with a minimum).
2) The module would be reprogrammed, under the 3 year / 36,000 mile warranty, in such a situation like this, I would agree. So now, it comes down to the exact terms stated in the extended warranty. Clearly, the extended warranty does not cover module updates for the sake of updating. The question is, does it cover module updates that fix an issue that IS covered under the extended warranty? If a TSB had been issued, then it should be no question. If not, then it seems gray.
Status
