Range difference between’23 and ‘24.
Boomerlang
Bryan
Orlando
Manager
Had (and LOVED) a ‘23 Lucid Red Lariat, 131Kw battery. At 100% charge, showed 320 miles range. Due to incredible lease deals, traded it for a ‘24 Platinum in Star White, 131Kw battery. But only shows 275 miles at 100%. But, does seem to be more accurate regarding miles driven vs. range depleted. ?
Also, Platinum level, but didn’t come with HomeLink visor, rear seat under storage box, and (because the power boards just aren’t me) the solid boards have deleted the rear LED lamp. Two weeks now and still exploring the differences.
Henry Ford
I just learned that Rapid Red changed to Lucid Red.?
Platinum is and has always been EPA rated for 300 miles of range. It's a bit heavier and the wheels are a bit heavier. I've gotten about 2.0-2.1 m/kWh in the 25,000 miles I've driven my 2022 Platinum. About half of those miles were on Lariat wheels and tires. Your mileage may vary.
The heat pump on the '24 should improve range in the colder months but I don't know how much you'll notice it in Orlando.
Also only has 48amps max AC charging vs. 80amps on your 2023.
