Sounds Good Stereo Behind the Seat kit installation
kvasiir
San Jose, CA
2022 F-150 Lightning Lariat Rapid Red
I bought this kit way back at Black Friday and finally got around to installing it. Well most of it, anyway. My truck was incorrectly reassembled in lot of ways by a body shop recently, so I'm waiting for them to fix their mess before I do the driver door.
The following posts are a bunch of pictures and instructions should you wish to do something similar. Today I'm just posting the rear door installation. When I do the driver door, I'll get pics of that and post. The electrical/cabling installation I have fewer pictures of, since I didn't think of it as much while doing, but I'll see what I can cobble together in the future.
Ok... here we go!
kvasiir
kvasiir
San Jose, CA
Before pic of some tools - 1/8" drill, 7 mm socket, trim tools, a little flat-head screwdriver, roller, measuring tape, trim tools, knife, scissors. Block-off plates, foam surrounds for the speakers and the speakers themselves too.
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 01-tools-
Sound deadening mat and a box of tiles. Have a trash can handy and something to sit on.
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 02-deadening-
Inside of the door (before shot):
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 03-before-
kvasiir
kvasiir
San Jose, CA
Under the handle, pop this guy off with a trim tool, then remove the bolts with a 7 mm socket.
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 04-under-handle-
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 05-under-handle-
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 10-handle-screws-
kvasiir
kvasiir
San Jose, CA
Pop this red plastic bit out with a tiny screwdriver:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 06-reflector-
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 07-reflector-
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 08-reflector-
Then remove it and the two screws at the bottom of the door card with a 7 mm socket.
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 09-under-door-
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 11-other-screws-
kvasiir
kvasiir
San Jose, CA
Lift the door off (not too far, you've gotta disconnect some stuff):
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 12-lift-door-
And remove the lock cable:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 13-lock-cable-
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 17-lock-cable-
The door handle cable:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 14-handle-cable-
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 18-handle-cable-
and the wiring harness.
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 15-harness-
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 16-harness-
kvasiir
kvasiir
San Jose, CA
Behind the door card:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 19-inside-
Remove the speaker, peel off the vapour paper, and then test fit the block off plate.
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 20-plate-fitting-
Mark a couple of spots, drill 1/8" holes, and put in two screws to hold it in place:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 21-plate-two-screws-
Then drill the rest of the holes out and remove the block off plate. Stick a couple of the screws back in so you can find the holes later after installing the blackhole mat stuff.
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 22-plate-holes-drilled-
kvasiir
kvasiir
San Jose, CA
Fill up the door with the sound deadening tiles. Make sure not to get in the way of the window rolling down. Mostly that means stick the tiles only to flat surfaces inside the door - not over any glue joints or support bars, etc.
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 23-sound-blocks-
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 24-sound-blocks-
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 25-sound-blocks-
kvasiir
kvasiir
San Jose, CA
Push the wiring harness and handle/lock cables into the inside of the door:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 26-cables-pushed-in-
Then measure/cut/trim black hole mat to fit everywhere. Cut out holes for the block off plate, the speaker, and any spots you need to get access to clip mounting holes or around where hardware goes when putting the door back together. Please forgive sloppiness and mistakes - I am no pro at this stuff!
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 27-bottom-mat-
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 28-all-mat-
Pull the cables back through and mount up the blockoff plate and new speaker.
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 29-plate-and-speaker-
Grab the speaker surround foam, stick it on, and trim to length.
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 30-speaker-foam-
kvasiir
kvasiir
San Jose, CA
Before and after pics of sticking more sound deadening blackhole mat material into the inside of the door card:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 31-door-card-before-
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 32-door-card-mat-
Then hook the door card back into place:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 33-done-
Finish up by reinstalling screws and panels and done!
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
You may not be a pro but it's looking damn good so far.
Thanks for sharing.
kvasiir
kvasiir
San Jose, CA
Front door time!
Here's where I sit and the trash can I use to throw waste in while I'm doing all the tiles and black hole mat stuff. Definitely good to keep the trash can handy.
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 02 trash and stool
And here's the door "before" pic:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 01 before
Once again, the door handle panel pops off to reveal two 7 mm screws:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 03 handle
And another one hiding behind this red plastic cover:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 04 reflector
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 05 reflector removed
kvasiir
kvasiir
San Jose, CA
The front door has one more bolt hiding behind this upper panel:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 06 upper panel
It pops off straight away from the door (watch out for the wiring harness behind). The bottom clips were a real PITA. Here it is removed:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 07 upper panel removed
And you can see another 7 mm screw hiding back there:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 08 upper panel screw
kvasiir
kvasiir
San Jose, CA
Now the door can be popped off (not too far, got wires and cables back there):
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 09 door popped off
Then unplug the lock cable:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 10 lock cable
The handle cable:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 11 handle cable
All the many and various ends of the wiring harness:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 12 wiring harness
And then hey presto, door card removed:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 13 door card removed
kvasiir
kvasiir
San Jose, CA
Same as the back door now, test fit the blockoff plate, drill all the holes, remove the plate, and put a couple of screws back in as markers.
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 14 block off plate drilled
At this point, you can stick in all the internal sound deadening tiles everywhere you can fit them (no pic this time, sorry).
Then clear off the rest of the door to put on the blackhole mat. This sensor needs to come off (two 7 mm screws):
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 15 sensor
And also this ECU. Four zip ties and two mounting clips. Make sure to check the routing so you can replace the zip ties when you put it back together.
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 16 ecu
Bonus pic of the ECU harness removed:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 17 ecu wirin
Then shove all those cables and wires back into the door body:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 18 tiles done cables pushed in
And install your blackhole mat, then pull all the cables back out, reroute them, mount the speaker, put in the speaker foam, and install the blockoff plate:
Ford F-150 Lightning Sounds Good Stereo Behind the Seat kit installation 19 blackhole mat
