Tire pressure changes in winter
Bushwood CC
Pete
Ford Lightning Flash
teacher
Winters in mn cause quite a change in tire pressure. Factory calls for 42 psi but if I set at that it will go up as the day gets warmer to as much as 46. Do I aim a little lower to start, say 40?
Bushwood CC
Pete
teacher
Thanks! That puts my mind at ease.
Good writeup. You fill tires COLD. People who fill up at Costco or a tire store are underfilling, as the writeup notes (yet the tire store doesn't adjust for that....).
Check tires at least MONTHLY with a tire gauge. TPMS is not a tire gauge...
I did mine in November, and they are currently 2 pounds light. Will be doing them today.
Last year took a trip to CA in winter. Weather was unusually warm, tires were routinely 48 to 50 while driving.
Calvin H-C
Calvin
As @RickLightning said above, you check and fill tires when cold. The rating is based on the fact that driving will warm tires and increase the pressure (anyone remember pV=nRT?*).
A significant change in temperature (5-10 degrees) might warrant rechecking them.
I find that temperature changes affect the Lightning's 20" tires more than our FFE's 17" tires (that pV=nRT thing again).
* For those who didn't take physics, or forgot all that stuff you don't use daily, basically p is pressure, V is volume, T is temperature, n is the amount of air and R is a constant. You can Google it if you have nothing better to do. ?
potato
BC, Canada
2023 F150 Lightning XLT ER
Parked in my driveway, the tires on the sunny side are usually about 2 PSI higher. Temperature definitely makes a big difference
Yup. So, that's really NOT a cold temp. If the non-sunny side needs 2 more pounds, then add 2 more pounds to the sunny side too from whatever they are.
