Tow Hook removal
agentorange
Tennessee
F-Series
ME
I just recenlty bought my 2021 reg cab, short bed. The truck is a 4x4 and I want to remove the tow hooks and replace with covers or lower valence that comes standard on a 2WD. Anyone have a part number? Thanks.
Pedaldude
Arizona
2001 Lincoln Navigator, 2021 Ford F-150
Find the VIN for a RWD truck and go to parts.ford.com and you should be able to find the alternate parts numbers.
Good luck!
ShawnWillis
Shawn
Tampa, FL
Ford Bronco 2014
Thanks for the tip, Pedaldude! Might as well take note of that.
JoeMo
St. Louis, MO
2021 f150 Powerboost lariat sport
How did you go about taking the tow hooks out? Iā€˜m looking at powder coating mine but I can’t find any videos specific to the 2021
jeffcrum
Jeff
Slidell, LA
Computer programmer
Two bolts on each straight from the bottom.
JoeMo
St. Louis, MO
No need to take the bumper off then? I ordered my truck 6 months ago and still don’t have it so I can’t go look at one. Thanks for your help!
christophers
Christopher
Austin, TX
2021 F150 Platinum Hybrid
You need to pull out the rubber/plastic thing, then you can get straight into the forward bolt from below. The rearward bolt can be accessed with a crescent wrench from underneath the truck. No need to remove the bumper.
DO BE SURE that you account for the nuts inside the square channel/frame. They are not held on, so when you pull out the tow hook bolts they will likely move. I used a coat hanger to put them back in place so I could thread onto them.
