dhrandy
- First Name
- Randy
- Jul 25, 2021
- Concord, NC
- 1950 Plymouth, 2021 F-150 Lariat 500a
- Occupation
- Engineering Tech
It's payload, not towing capacity (probably what you meant to say). Like you pointed out hitch weight adds to the payload. I would calculate 12.5% of the GVWR to get an average. You should also add any accessories, IE: bedliner, bed mat, gear in bed, rubber truck mats, tonneau cover...etc to the payload. Also add the weight of the distribution hitch or any hitch you have on there. Weight distribution hitches weigh anywhere from 50-100 lbs. Want to lighten the hitch weight? Buy a lithium battery if your battery is on the tongue.Just going off this sticker and some assumptions:
Summary: I your loading sticker indicates that you can place 1,723 lbs into your truck. Assuming you are towing alone and only weigh 150lbs you are well below the max tow rating IF your tongue weight is only 1,390 lbs. (WITH LOAD DISTRIBUTION) <--- This part really chaps my ass because you can't put more than 500 lbs without load distribution on the factory IV hitches. I bought a CURT aftermarket for my 2018 so I could have more tongue weight without weight distribution, the truck looked stupid with two hitches.
- Towing capacity is assuming 150lbs for driver.
- 1723 - 150 = 1573lbs if this is your max capacity of your truck after you add a driver.
- Towing you put 10-15% of the total weight towing onto the tongue. Lets assume 10%
- Towing chart says 13,900lbs for your configuration with 53C so 1,390lbs tongue weight.
Disclaimer: I still don't fully understand why FORD doesn't put GCVWR on these trucks, so I can't say "you're good" its just the calculations I ran that said I think you're good.
