Upgrade to 7.2kw Pro Power ?
Blochead21
PA
Black 22 XLT 311pkg
Are you sure that is the same part # for the lightning with the 9.6kw pro power?
That was the number found when I looked it up online. I would double check with a dealership before buying it though.
mr2urbo004
CA
2023 Ford F150 Lightning Pro, Tow Tech,
I picked lightning and it said it is not compatible.
Ricks Lightning
Rick
Los Angeles
2023 F150 Lightning Pro, 2024 F150 Lightning Flash
Plumbing Contractor
almost sure there are 2 different inverters. the standard powers the frunk and interior. the 7.2 powers the bed and 240 via 3600 x 2. 9.6 is a combination of both inverters.
Rick
OMO7
23 Lightning
Night Vision Camera - Ford (ML3Z-3G592-B)
How about night vision? THis is part for the Ford F150 Lightning.
Bluecruise. Which raises the question, can that be installed "aftermarket"?
mr2urbo004
CA
Rick
It should be 2.4kw and the 240v is 7.2kw power. The front and interior is always 2.4kw
Azgunguy
Michael
Northern Arizona
2023 Lightning Pro and 2012 Expedition Fleet
Has anyone been able to successfully add the second inverter?
FoxRidgeFarm
Gordy
Farmer
I found that the 7.2 kw pro power feature in 2024 is now a dealer installed option
ture to a 2024 Ford F-150 Lightning at a dealer is around $750. This feature requires the hybrid powertrain.
The Pro Power Onboard feature allows you to use your vehicle as a power source for electronic devices and power tools. It has three output levels: 2.0 kW, 2.4 kW, and 7.2 kW. The 7.2 kW generator has up to six 120V/20A outlets.
