Upper Control Arms compatible with OEM wheels?
haroldt
Harold
2023 F150 Lightning Lariat ER in Azure Gray Metallic Tricoat
I've got a pair of Bilstein 6112s headed my way on the #5 setting, which will give a mild lift (1.4" or less). I probably don't need new UCAs, but I'm considering a few options:
Both product descriptions prescribe aftermarket wheels with less backspacing. My OEM wheels have 6.52" of backspacing, and I'm looking to confirm with any other Lariat owners that either of these UCAs will infact work without interference.
Just looking at the stock UCAs, I don't understand how anything aftermarket would be see different that it would interfere. I feel like this might just be a very broad CYA and opportunity to sell wheels...
csukoh78
Nope
SE USA
2023 Ford Lightning Lariat ER
The icon upper control arms are amazing, extremely well-made, quiet, facilitated an easy alignment even with a lift, and had no rubbing or any other issues. When I crashed my truck, losing those arms was the one thing I wish I had been able to grab off of it
haroldt
Harold
@csukoh78 which wheels did you have, and what were their dimensions?
csukoh78
Nope
SE USA
https://vorsteineroffroad.com/products/vr-602-carbon-graphite
WHEEL SPECIFICATIONS
Wheel diameter (IN):20
Wheel Width (IN):9
Bolt pattern:6x135
Wheel weight (LBS):28.6
Offset (MM):+12
Backspacing (IN):5.5
Hub Bore (MM):87
Max load (LBS):2,645
The front suspension on a Ford lightning is identical to a regular F150 and if you do any sort of lift, you have to get longer control arms so the truck drives perfectly straight, doesn't hit the suspension, and is easy to align.
