Videos: 360-Degree Cameras In Use While Driving
Merccat
Ryan
2021 Space White Lariat SCAB 5.0 4x2
I could also be wrong about the firmware requirement altogether, and the thing holding us back from this feature might just be that we need the latest Sync4 update that will be coming soon.
Boy I hope so. I have a mid-late July build and it does not have the feature…. However, was ordered at the beginning of the year so not part of the build 2 group (where they added the scale, etc)
diesel97
rob
Ford Edge
electrical
I know it's on the new Tremors for sure. I have high hopes that ford uses the OTA system to bring early generations up to speed with the newer firmware.
Either way, we will likely be able to obtain the new firmware at some point and can do it ourselves.
Does it work on the Tremors in all modes?
Drandpa
Home
2021 f150
In trucks with park assist the front cameras will come on automatically if an object is detected nearby.
I do wish that they would come on sooner though as I have to creep up on something for what feels like a long time after it’s out of my visibility before the camera comes on automatically. I’ll probably eventually get used it but yeah for now I am hitting the button half the time.
The other thing that bugs me is if you have the camera on, then shift into reverse to reposition… when you shift back into drive the cameras are off again, regardless of speed and you have to turn them back on. They should stay on once selected even if going back and fourth.
I know this isn't exactly what you are wanting but there is an option called "delay camera" or something like that. If you set that on, when you go from reverse to forward the backup camera stays on even while going forward until you hit 6 mph. If you have the 360 cameras, I usually find that good enough that I don't have to re-enable just the front view. Perfect for those quick back and forth maneuvers.
Merccat
Ryan
Awesome thanks! That should actually help quite a bit, I’m going to look for it now. Hopefully it also helps keep the camera on while swinging into a space…. I’ve noticed that the cameras come on when the corner of the truck gets near a car but as soon as I slow my approach they immediately turn off.
Edit: ok I give up, where is this option… I looked through settings, the manual and the forscan spreadsheet.
Edit edit: found it under features—>driver assist. It would still be better if it would switch over to the front camera but at least keeping the 360 display on should help, looking forward to trying it.
kly
Kevin
Central PA
2021 f150 Powerboost
I am die hard Ford, BUT I rode in a new Chevy even before I ordered my 21 Lariat. Their cameras are awesome. When towing they can turn any camera on. You can see the hitch while driving, when turn signals are turned on the side cameras turn on and you can see down the side of your truck and trailer, they even have a rear view camera on the rear view mirror which is more clear than live viewing. Right now I think Chevy is way ahead of Ford technology.
Does any one know if there is some way to contact Ford to see if there are any updates.
nsbreeding
Neal
Louisiana
F150 Lariat 2021
... Their cameras are awesome. When towing they can turn any camera on. You can see the hitch while driving,
Has anyone tried the cameras in trailer hauling mode or with a trailer hooked up to see if it will stay on?
kly
Kevin
Central PA
Camera does not come on or stay on, very disappointing. Except for backing up I do not know what is the advantage of the cameras.
Blueshound
Connecticut
2021 F150
There's an option for that
Ford F-150 Lightning Videos: 360-Degree Cameras In Use While Driving Screenshot_20210920-134124
Roady
Cory
Northeast PA
2021 F150 XLT FX4
Information Technology
Parking in my garage.
Parking in a crowded parking lot.
Verifying I'm centered in the lines when parking.
Just to name a few.
Merccat
Ryan
Yeah it helps and is better than nothing but it leaves you stuck with the rear camera on while moving forward instead of switching back to the front camera. At least the 360 view stays up.
Zyvin
SC
2021 F150 Crew, FX4, Lariat
Yea, it seems very restricted for what it “could” or “should” do. Even the Camera module (IPMA) has line options in forscan for turn signal view, video on demand, view at speed for hitch and bed, etc. I believe the APIM gets its speed signal from the PCM (I haven’t looked to see if that shows on forscan)as it’s not listed on the spread sheet. It’s annoying as there are so many options locked out.
I haven’t tried a different country code to see if any of it works (like it does for entering gps destinations in motion).
It may take navtec or 4d to work out the issues, but they will.
JHForman812
Indiana
2022 F350
Cool, is that in any driving mode? Looks like I’ll have to get some f250 forscan settings for the ipma and maybe the BCM.
Sorry for the late reply, I can access my hitch camera, and bed camera at any speed in forward or reverse. I cannot access the front camera though.
kly
Kevin
Central PA
Is there a way I can make this happen on my 21 F150 Lariat?
JHForman812
Indiana
2022 F350
Keep in mind i have a 22 super duty, I am not sure how ford has it disabled in your alls trucks, theres a lot of people working on it though. it could be a software deal or a firmware deal. be patient it will get figured out.
