- First Name
- Brandon
- Jul 26, 2022
- Tucson, AZ
- Honda Pilot, 2022 Lightning ER
I'm getting a lot of different numbers between what the truck shows at the end of a trip and what shows up in the FrodPass trip log. What is the most accurate way to determine our efficiency? If I believe my logs, I'm averaging around 3.0 m/kW on my daily commute (which is 27.5 miles each way, 300ft elevation drop between home and work, 65/35 city/freeway). Lows in the upper 30's, highs in the 60's (70's next week), no preconditioning as I don't have level 2 charging at home yet. The trip log in the car is anywhere from +/- 0.2 to 0.4 off from the logs.
Should I start noting the % at start/stop and compute it that way? How much error does that introduce since it's either rounding or truncating. Are the logs reliable so long as they start/stop correctly?
