Work truck topper installed, cameras and sensors not working.
dahlio
mike
2024 lightning flash
plumber
Hi, I’m a plumber and had a full comericial topper installed to carry pipes and tools. The tailgate was removed because the topper goes down to bed. Now my front camera and other cameras are not working. It says the tailgate is open and sensors not working. I see two molex connectors that are disconnected under the bumper. The tailgate has those two connectors hanging off the bottom in my garage.
Has anyone gone through this conversion before. Is there a way to bypass anything or take apart the sensors from tailgate and connect them under the truck? Any insight would be appreciated. Thanks
Ford F-150 Lightning Work truck topper installed, cameras and sensors not working. IMG_2439
SpaceEVDriver
Arizona
The manual has a description of the steps required. I'm surprised the installer didn't do this properly. There should have been a cap in your glove compartment that is plugged into the tailgate electronics harness.
dahlio
mike
plumber
They didn’t install the plugs. I just found them and installed them but other cameras are still disabled.
Wattsgas
MIke
Brinnon, WA
Try the old detach the 12VDC negative terminal for a bit and reconnect to reboot the system. It is the mystery repair for bugs with the Lightning. Sometimes it just has to forget to remember.
dahlio
mike
plumber
Unfortunately the unplug method didn’t work. I found a similar issue on regular fords forum for trucks with a power tailgate removing for campers/toppers etc. seems like the ‘23s are fixed with the wiring caps but ‘24s are having issues
