NiftyF150
Tony
2021 F150 XLT Sport Leadfoot Gray 302a Ecoboost
Maintenance Supervisor
Installed a 2.5” Supreme Suspension Leveling Kit today. Top pics are stock, bottom pics are with leveling kit installed.
Sorry for the dirty truck. It’s -18 degrees here in MN right now so car washes are closed.
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed 28A946BF-7B22-4CCE-9AFD-C236E553449E
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed 52643A25-B9B4-4C51-B4AC-0D6F387B61F1
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed 1736DC70-DE68-4B04-AB8C-FD88E6E94494
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed F4814BB2-9868-4D54-B9A0-C887287EF672
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed A76F98F9-4C64-48DD-B536-9797A275FE36
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed E610A210-CC8E-4CD8-966C-20C9851C7CAF
A few more pictures for your viewing pleasure with some of the new suspension components for 2021.
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed 13496b44-31ed-4205-85c1-c6137598831c-jpe
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed cf3aa4f4-5eac-42df-bdf5-939af94da43a-jpe
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed 9ffc0a7a-f895-490a-8792-a5c06a90799c-jpe
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed ac3e3f5b-76a6-4a70-9fbb-5fd0060c6a44-jpe
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed 5bb250e8-bba1-4f6b-81eb-d72a313034d5-jpe
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed 1a63205e-ee58-4077-8355-04a43e88d7d6-jpe
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed 84d3c9b2-622c-4d4f-939f-7abef33f9ed4-jpe
mnstang
Nick
MN
2021 F-150 Lariat PB Leadfoot
US Gov
Looks great! Did you install yourself? Nice to see a fellow Minnesotan on here!
NiftyF150
NiftyF150
Tony
Yes I installed it myself. There were a few things different with these 21's vs the install videos on 13th gens but it was pretty straight forward. Notable differences being that you no longer need a vacuum pump to remove the steering knuckle and the sway bar link is different now too. I was able to access the strut bolts from the wheel well with a ratcheting 18mm, even though I've heard multiple places that they have to be accessed through the engine bay.
StangTech
2018 F150
Great looking truck!!! Are those tires stock or did you upgrade them? I like the white lettering.
mnstang
Nick
MN
US Gov
That was my next question. I’ve also heard that the bolts needed to be removed via the engine bay. I want a level too but I dunno if I could do it myself. Are you going to get an alignment done?
NiftyF150
NiftyF150
Tony
Thanks, yes these are the factory tires that came on the truck. The white lettering is just more prominent with the wheels blacked out.
I will warn you that this is a solid 3.5 out of 5 on the difficulty meter. If I didn't have air tools & a heated garage I wouldn't even bother. The couple hundred bucks you'll pay for install would be worth it. I'm no newb when it comes to wrenching, but I'm not a mechanic either.
Yes I'm going to get an alignment within the next 500 miles along with my first oil change.
Elkhunter
Monument Co
2021 F-150 Lariat
Looks awesome brother!!!!
NiftyF150
NiftyF150
Tony
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed 13496B44-31ED-4205-85C1-C6137598831C
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed CF3AA4F4-5EAC-42DF-BDF5-939AF94DA43A
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed 9FFC0A7A-F895-490A-8792-A5C06A90799C
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed AC3E3F5B-76A6-4A70-9FBB-5FD0060C6A44
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed 5BB250E8-BBA1-4F6B-81EB-D72A313034D5
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed 1A63205E-EE58-4077-8355-04A43E88D7D6
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed 84D3C9B2-622C-4D4F-939F-7ABEF33F9ED4
cakryg
NY
2004 Tundra
Are you taking it in for an alignment? Also, I love the olds in the other bay. I had a '70 cutlass in high school that had way too little traction for a teenager.
NiftyF150
NiftyF150
Tony
Yes I’ll be getting an alignment within 500 miles and my first oil change.
Thanks, that’s my other toy. 68’ Olds 442, 400ci Big Block, blue printed & balanced, bored .06 over, 455 torquer intake manifold, 750cfm carb, electronic fuel pump, 4 speed manual w/ 4:56 gears. She’s a throwback to a different time and truly feels like an occasion every time I drive it.
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed ACF41FE2-AD2D-49AE-9D3F-747762057D92
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed 3C904E13-426A-4901-94C1-B78B529FFE4B
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed 7C041383-CB3B-48AA-89DB-84BFA74E967D
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed 61B34AC4-5542-480D-BC62-2BAC8DE4A3BF
NiftyF150
NiftyF150
Tony
This is where I ended up fellas. 39 3/4” up front vs 40 3/8” out back. Removed roughly 3” out of the 3.5” of take the truck originally had. That’s pretty level I’d say.
Ford F-150 Lightning 2.5” Supreme Suspension Leveling Kit Installed 29ADF144-295F-435A-BA55-8336D0F48DF6
150ish
Scott
2021 Ford F150
Inspector Gadget
Very cool! How are the half shaft angles with the 2.5”?
NiftyF150
NiftyF150
Tony
150ish
Scott
2021 Ford F150
Inspector Gadget
This is hanging by the way, not under load.
Thought that was pretty steep at first. I didn't see the hanging part right away. I'm sure sitting on the ground will knock out at 3-5 degrees.
NiftyF150
NiftyF150
Tony
I'll pull it up on ramps this weekend and get a picture under load for better reference.
