Michael
BMW X5, BMW 528, Porsche 928
Sales Leader
Just had Toyo ATIII EVs (275/65r20) installed on my stock '23 Lighting Lariat (Max Tow). Replaced OE tires (275/60r20). The new sized tires fit without a lift or leveling kit. Pictures below...
Ford F-150 Lightning 34" tires on stock - THEY FIT IMG_6704
CaseyCo
Casey
Denver, CO
Looks good! What kind of drop in efficiency have you seen so far?
LightningSauce
Michael
Sales Leader
Not sure yet...just had them installed today and drove ~8 miles home. :cool:
Nolander
Scott
Following. Curious, how many miles did you get out of the Hancook’s?
NW Ontario Ford Lightning
Robert
NW Ontario Canada
2024 F-150 Lightning XLT
Contractor
Interested - hope you post the net results for everyone here.
I myself am interested in options for next winter, will run the factory set until next fall, then switch to a more suitable winter tire.
They look great!
Any rubbing? How's noise compared to stock?
jetfixr1
Manny
Atlanta
2023 F150 Lightning Lariat ER
Still running factory Hankooks at 30K miles. Looking at replacement around next fall which will bring me around 45K. Id love to hear your thoughts and observations on these.
LightningSauce
Michael
Sales Leader
Additional notes/responses :
OE tire miles : ~15,000 miles; Tread was still great all around.​
Rubbing : none that I know of; plan to make a video of wheel range to ensure​
Efficiency : to be determined;​
Noise : did not notice anything outrageous and I drove home with the radio off.​
Pressure : 41 psi (new and old tires)​
Since I purchased the truck, i wanted to beef up the wheels...so I waited ~2 years to replace them. I work from home, so my annual miles are limited. As I drive more, I will update the thread with efficiency numbers.
roddiaz1
Rod
Pittsburgh
I got rid of my Hankooks at 36k because of uneven wear (caused by the front end).
jetfixr1
Manny
Atlanta
Do you know what was causing the uneven wear?
roddiaz1
Rod
Pittsburgh
I was unable to get to the bottom of it, but my guess it is camber/caster issue.
jwcrkelly
Kansas City
F150 Lighting Lariat
I got about 40k on my Hankook’s but they were BADLY worn on the inner and outer edges. My daily commute has several roundabouts but I felt they still wore quite badly along the perimeter.
I have about 6k on the LT275/60R-20 TOYO OPEN COUNTRY A/T III EV E and I love them. The look, feel, and lower than expected road noise. I believe when I bought them back in October 2024 they only had the load E version?
Range is probably a tick lower but didn’t benchmark old vs new.
I think I need to increase pressure though. At 36 psi, they look a little low. Do we have a published psi from Toyo or Ford on these Load E tires?
roddiaz1
Rod
Pittsburgh
At what intervals did you have the tires rotated?
About every 10k miles. (wouldn't have the patience to do it any more than frequent than that). My other vehicles get rotated every 20k or 25k without issues.
Jamchampnate
Nate
Utah
Ford lightning
Yeah for those that aren’t aware the outer edge wearing poorly on the factory hankooks is widespread. Doesn’t matter how much you rotate. They don’t sell them with those anymore for a reason.
