stangsandatruck
- First Name
- Chris
- Mar 15, 2021
- NE Pennsylvania
- 2015 Mustang GT, 2021 F150 XLT 302A
- Occupation
- Software Engineer
So i ordered the tail light kit from Diode Dynamics for the 2015-2021 F150. The kit included 4 7443 bulbs. Went to install them and they did not fit, so I reached out to DD. I worked with them to get the specs of the 302a bulbs - which the measurements state its a 4257. Turns out the 4257 the same as the 3157 where you need to cut the tabs off the 3157. For Diode Dynamics - I was told that the tab modification would not void the warranty (3 years) and Iād have no issue if they were exchanged and missing the tabs. I intalled them and they do work great. The fitment is tight so the bulbs will not flicker or come out. Overall a great modification to the truck - you can really tell the difference between the stock and the LED upgrade.
TLDR - If you have the XL or XLT w/ BLIS - donāt order the kit from DD. Order 4 3157 bulbs and modify the tabs to fit the socket.
Side note - the team at Diode Dynamics was great to work with directly, they even offered to send a few different bulbs if the modified 3157s did not work. The bulbs were quite expensive, but the customer service was great in getting me the correct bulbs, so it was worth every penny.
