dog_tired
Jumping in here late, but I too had this issue.I have a new 2021 f150 power boost.
I purchased a 2020 airstream and towed it 10.5 hours from Wisconsin to Nebraska.
I set the trailer brake fine in Wisconsin and it seemed to be working without issue. I did mess with the gain a lot trying to get it right.
I parked in my driveway for 3 days and when i towed it to storage, the trailer brake was not working.
It would show my trailer connected, and allow me to select the trailer, but when I would try to manually squeeze the trailer brake a screen popped up saying “no trailer” and the brakes were clearly not engaging. (I noticed this because I could tell I was getting pushed when i got off an exit ramp.)
Anyone seen this happen? I checked the 7 pin connector and it looks like new. I was thinking it may be a fuse in the truck - but didn’t have time to check.
When the trailer is not connected at all the message from the trailer brake is a bit different, showing a pop up that shows trailer disconnected. When trailer was connected, it popped up like it should - but underneath the gain settings shows “no trailer” and the brakes don’t work.
I should also add that the signal lights, brake lights and everything else seem to be working on the airstream.
Turns out, the batteries on my airstream were not producing enough amps and needed to be replaced. Issue solved.
