BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
Installed latest script iPhone 12 Pro. Works but still can’t change metric to us, ie miles vs kilometers. Click on setting, screen jumps but still says metric.
tonesto7
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
ok I will investigate.
tcp
Trieu
Kansas City,MO
2021 F150 Platinum, 2019 Accord
IT MGR
I'm on the new script version and the home screen widget no longer works. Error says "Alerts are not supported in a widget" Also notice that my session is not staying logged in, keeps prompting to login with un/pw and VIN every time I open. Seems like the new code is clearing cached credentials or something.
Maybe this part of the change is causing this >>>
  • Added the ability to hardcode an id into the script to allow for multiple instances for multiple vehicles. See the SCRIPT_ID in the script header (Not fully tested).
tonesto7
tonesto7
Anthony
Tap on the widget to run it manually and it should work.
tcp
Trieu
Kansas City,MO
IT MGR
It works when I run it manually but for some reason the IOS home screen widget no longer works. It may be related to the always prompting for creds now when I run it manually. When I remove the widget from home screen and readd it briefly display data then errors to the error.
tcp
Trieu
Kansas City,MO
IT MGR
Screenshot of error.
Ford F-150 Lightning FordPass - Scriptable Widget (iOS, iPad, MacOS) 1639877865442
Bassjammz
Jeremy
Ohio
2021 f150
Ford F-150 Lightning FordPass - Scriptable Widget (iOS, iPad, MacOS) 1639880040680
I am getting this error. Any thoughts
tonesto7
tonesto7
Anthony
Open the scriptable app and tap on the ... on the ford pass widget.
Slide up the log view and press play bottom right.
Try logging in again. If it fails review the logs.
Bassjammz
Jeremy
Ohio
2021 f150
Ford F-150 Lightning FordPass - Scriptable Widget (iOS, iPad, MacOS) 1639881654144
It runs but still the same error
tonesto7
tonesto7
Anthony
There is only one location in the code that the widget itself uses the Alert functionality and that's in the new vinCheck() function.
It checks to make sure your VIN is correctly formatted and doesn't contain any special characters.
I just added a check to prevent the alert function from being used.
Bottom line it doesn't like the format of your VIN
Code:
async function vinCheck(vin, setup = false) {
    vin = vin || (await getKeychainValue('fpVin'));
    let vinLen = vin && vin.length === 17;
    let vinChar = vin && vin.match(/^[a-zA-Z0-9]+$/);
    let msgs = [];
    if (vin) {
        if (setup && !vinLen) {
            msgs.push('VIN Number is not 17 characters long!');
        if (setup && !vinChar) {
            msgs.push('VIN Number contains invalid characters!\nOnly A-Z, 0-9 are allowed!');
        if (msgs.length > 0) {
            console.log(`VIN Format Issues | Current VIN: ${vin} | Errors: ${msgs.join('\n')}`)
            if (!config.runsInWidget) { //Added this to prevent the Alerts not supported in widgets error
                await showAlert('VIN Validation Error', msgs.join('\n'));
            return false;
        } else {
            return true;
    return false;
tonesto7
tonesto7
Anthony
@tcp You need to remove that token info ASAP... It's not going to allow someone access because it expires after a few minutes, but shouldn't share it none the less.
I don't see any reason why yours isn't working... I did see someone report that the deviceLanguage variable was causing a constant login prompt. I will remove that variable requirement.
Reactions: tcp
tonesto7
tonesto7
Anthony
tonesto7
tonesto7
Anthony
I just remembered the last release pulls in your units of measurement from the ford API on your account. It should match what is shown in the FordPass app.
