pavementends
That Kicker Keyloc Smart LOC is pretty cool, actually. Would you recommend splicing into a rear door speaker or a front door speaker? Any difference/advantage?Yes that will take high level in, so dont need an LOC, but an LC7i will flatten the EQ curve the factory installs, known as bass rolloff. so you can boost with the powered sub and get all the bass freq you want.
If you want both all in one, this will do the same as an LOC, and will flatten the EQ.
https://www.kicker.com/keyloc-smart-line-out-converter
Plus, it will tell you what wire you connect into into a harness
