SWAP B&O (non unleashed) subwoofer with Kicker Hideaway 10” powered sub?
kevojack
Carlsbad, CA
2023 Ford Lightning
I’ve been through a a lot of threads before posting this and sorry if this has already been answered. I’d like to swap the non-unloaded B&O subwoofer with a Kicker Hideaway 10” sub. Is this a straight plug n play when swapping for B&O subwoofer or is new wiring required? Having trouble finding a clear answer to this. Thanks!
kevojack
Carlsbad, CA
2023 Ford Lightning
There are more threads on the ICE version of this forum about stereo upgrades. This one might be exactly what you are looking for: https://www.f150gen14.com/forum/threads/adding-a-sub-to-non-unleashed-bo-system.3026/post-45064
appreciate the tip. I’ve actually read the entire thread lol. What is unclear to me is whether swapping the unit will require a more involved install—it seemed to me on that thread it was discussing adding the unit as an additional sub.
rugedraw
Javier
Miami
Auto Sales
I'm sure @SoundsGoodStereo can answer this and have whatever you need to get it done.
Reactions: GDN
SoundsGoodStereo
Gold Sponsor
Don
Mount Juliet, TN
soundsgoodstereo.com
F-150
kevojack
Carlsbad, CA
2023 Ford Lightning
Yes, this is a common setup but requires a few components to make it happen.
First, the HS10 + Bass Knob
HS10 on Amazon
Bass Knob on Amazon
Second, the bass roll-off needs to be fixed/corrected, so you need this interface
B&O Bass Roll-Off Fix Interface
Third, power + ground to the battery, do not use the cab. Here is a kit
8-Gauge Power and Ground
Fourth, when the factory sub is removed, you need to cover the hole
Subwoofer Block Off Plate
Last, enjoy the upgrade :)
Thank you so much, exactly what I needed to know!
sstevetx
Steve
