2021 leveling info with CCD suspension.
ewc0482
NC
2021 F150 Limited Powerboost
Sales
CapIrish, I’ve got the same truck and similar issue. I had a 2” level installed… I’ve got fuel sledge 22x10 +10 offset wheels and Toyo AT3 285/55/22 tires. When I get the truck around 50mph and higher the whole truck shakes. The installer has no idea on what the issue is. The only thing they haven’t tried is road force balancing. I did find this info on BDS site saying their kits would work on CCD equipped trucks but have not dug any further yet. I also seem to have a slight buzz or hum I can feel in the gas pedal and steering wheel at times. Just ready to get this figured out.
Ford F-150 Lightning 2021 leveling info with CCD suspension. 48D7C208-1E1D-4EBD-B7A0-3BA1E75F15F3
Ford F-150 Lightning 2021 leveling info with CCD suspension. 38408CD5-466C-4DE6-BBAF-A72AACBD68F6
Ford F-150 Lightning 2021 leveling info with CCD suspension. BB4D60B9-E30D-448D-96A6-36BE4CB1F8C5
chill_will
Will
Montgomery, TX
2021 Powerboost F150 Platinum 4x4
Shaking and vibrating is most likely your tires and not related to CCD or the level. Check your scales to see if the sensors need to be reset. Since I’ve done that, my truck rides almost as good as stock albeit with LT tires.
Ford F-150 Lightning 2021 leveling info with CCD suspension. 1E44C004-C3BE-4049-96B9-E04B626DB2FA
Ford F-150 Lightning 2021 leveling info with CCD suspension. D288FF20-2B3D-41A3-B64C-F58E80F06671
CapIrish
Sean
Oklahoma
2021 F150 Limited
That's interesting. I just talked to BDS last week and they said they have nothing in the works yet for the ccd. They haven't even seen one in person yet so they have no starting point. It seems that none of the lift companies have a clue yet but hopefully they figure something out relatively soon.
Steeler
New York
2021 F150 Lariat; 2022 F150 Limited
You guys have any luck with the readylift 2" level? I'm looking to level my Limted Powerboost and curious how you all made out.
Thanks!
JPSoup
Jared
Maxatawny, PA
'82 CJ, '18 F150 KR, '22 F150 Platinum (soon)
Sales
Ordered my '22 Platinum PowerBoost yesterday. I'm going to level it. Have a couple of quick questions:
1) Won't any kit work? What makes Redilift different?
2) Think leveling bags on the rear would screw with CCD and scales? I haul a TON of wood and want to transfer my bags from my '18 KR to the '22 Platinum
gendibal
M
DMV
Ordered: 2022 F150 Platinum PB
CCD should be fine, Smart Hitch is a different situation. I’ve emailed with all the manufacturers of helper spring setups and bump stop replacements, yet to get a good response on the Smart Hitch. My sense is they're not compatible unless there are recalibration with new deflection parameters for the system (and not sure if that’s even possible).
MBE
'20 Road Glide Special, '12 Tacoma, '22 F150?
Still good on my side.
Will, thanks for the updates. Your F150 looks excellent!
I have confidence in my plans for the '22 Limited(when it arrives) due to 3 things; noted you are an engineer, you are in Texas, and you have tested the installation.
This is an excellent example of a hypothesis becoming a theory. There is a road trip to Tomball in my future.
chill_will
Will
Montgomery, TX
Haha thanks! The guys over at Allout Offroad know what they are doing. Keep us updated on yours!
Alexk
Alex
Portland
Order ‘22 F150 Platinum Powerboost Carbonized Gray
Have you revisited this yet? I see Readylift says the 3.5 works with CCD and I’ve see Atkins Ford (Real Deal Neal) did a 6” BDS lift As well. No idea how they managed the CCD errors with new shocks.
My plan is to go with the 3.5 and some 295 65 r20 on VenomRex VR 601 mystic black. Once my 2022 Platinum shows up.
https://www.readylift.com/3-5-sst-lift-kit-ford-f-150-2021.html
Juanesmin
Juan E
Odessa tx
F -150 2021 platinum
There’s any leveling kits for CCD suspension out there
Alexk
Alex
Portland
shokwave
mike
london ontario
2022 f150 limited, 05 mustang gt,2019 mustang gt
electrical contractor
Wowwwwww good to know! You should be fine with the 2” level. Sensors shouldn’t be touched.
Hello Will thanks for all your info I've purchased a 2022 limited with blue cruise and wondered if yours has it as well? and if it affects your autonomous driving. your truck looks great what wheel and tire combo did you go with.
